Supercharged 7.3 IDI ? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > F-250 & F-350 1986-1997 & Other Ford Trucks > 6.9 - 7.3L IDI Diesels 83-93 Model Years
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 09-05-2011, 06:14 AM
96powerstroker's Avatar
96powerstroker
Offline
Member's Gallery
A buddy of mine showed me one of his friends truck with a 7.3 IDI with a supercharger type blower on top the motor powered by the crank . Is supercharging a IDI even possible . like is it even possible that it could be done?
__________________
96 F250 2WD, 286K, Built E4OD, 180cc Injectors, Tony Wildman Tunes, Beans Fuel System, 3in DP - 4in MRBP exhaust, CAI, 4:10LS SCLB, Traction bars,
62 F250 4X4, 223 I6, T98 4 speed, 4:56s RCFS (Reg Cab Flare Side. Factory) 31x10.50x15s, currently on 16in Alcoas
Reply With Quote Quick reply to this message Go to the top
Old 09-05-2011, 11:22 AM
tjctransport's Avatar
tjctransport
Offline
just an old fart
Member's Gallery
Re: Supercharged 7.3 IDI ?
anything can be done with enough money.
is it economical or practical?? i doubt it.
our engines are turbocharged for a reason. the turbo is better.
__________________
tom
  #3
Old 09-05-2011, 03:03 PM
96powerstroker
Offline
Member's Gallery
like this guy is like 20 years old max. and still though poppin the hood and sitting on top the motor a blower thats pretty badass. cause u dont see it much
  #4
Old 09-05-2011, 03:32 PM
theSLEEPER's Avatar
theSLEEPER
Offline
<--Spy Vs. Spy
Member's Gallery
A blower on an IDI would probably work pretty well. Would it be worth it for the gain? Probably not. But it would be cool.
__________________
228-365-0698
Sheep only have two speeds, 'grazing' and 'stampede'.
Regulated Returns are on SALE!!
  #5
Old 09-05-2011, 05:13 PM
hairyboxnoogle's Avatar
hairyboxnoogle
Offline
IDI for life
Member's Gallery
well if he showed you a picture of it, i would assume it can be done I seen some pics over on OB about this, one with a 3.8 GM SC. He sees 2lbs at idle, overdrive the pulley and throw a turbo on there for top end and away you go, although im not sure how that exactly works and how much the heat the SC will make.
__________________
'92 F-250 Supercab long bed. ATS 088 for now
'79 F-350 Custom, Super Cab Flareside weighs in at 6460 -- 7.3IDI Diesel hx35/40-HT60,p-pump, ZF5/205
  #6
Old 09-05-2011, 05:29 PM
Petro's Avatar
Petro
Offline
IH Diesel Power
Member's Gallery
I bet i would actually work pretty good. It probably would be PITA and i probably wouldnt do it to an idi but like it was said earlier, put a turbo into the equation and the instant boost down low combined with the turbo for top end boost and it would be a very sweet combo. And on another note, idk how much boost you can push with a supercharger but i would think it would make 10 psi and alot of idi dont run over that anyway so im not really seein why it wouldnt work
__________________
Current
99/05 F250 XLT Ccsb 4x4, 7.3l, ZF6
, Power Struck Tuned, Luk Clutch, RR, Comp 910s, and more sh!t.
Sold
99 F250 Lariat Ccsb 4x4, 7.3L, 4R100, The Basics
Totalled
08 F250 Lariat Ccsb 4x4, 6.4L, 5R110, SCT Livewire IDP Custom Tuned, 5" Exhaust, Custom Traction Bars.
  #7
Old 09-06-2011, 12:33 AM
88 Ford's Avatar
88 Ford
Offline
Member's Gallery
On the note of a supercharger here is a thread with an awesome setup a guy builds and sells for Dodge Cummins. He has built two kits now and they both work well. The seconds one is nicer though. He says it tows better and really spools his big turbo well. Right now he is actually testing a third setup where he is using an Hx40 for the secondary and the SC as the primary. Its just awesome how is experimenting with so many setups. But anyway read through the thread and here are some videos.
Dodge Cummins Diesel Forum
http://www.competitiondiesel.com/for...d.php?t=110216
Here are also some videos of the first kit he sold to guy in Cali. It works pretty well too.
  #8
Old 09-06-2011, 12:43 AM
88 Ford's Avatar
88 Ford
Offline
Member's Gallery
Also here is a setup on another site that I found. Check it out.
pic of a super charged 7.3 idi that's pulling - Oilburners.net
This is my setup. I just gotta get my truck from Idaho before I can finish it. This is my SC and mount. The turbo will blow into the SC and then will go to the intercooler then to the intake. It will be regulated to 20 psi. I believe that using all the extra fuel down low will allow me to add more fuel without over fueling it, thus keeping egts down. I think that would also make it a good setup for towing. Here are some pics of my setup also. My friend built a 3" cowl hood to fit it under the hood.
  #9
Old 09-06-2011, 02:06 AM
Cat_Rebel's Avatar
Cat_Rebel
Offline
OBS junkie
Member's Gallery
Saw one on a 93 idi in a 69 Ford F100 this weekend. It made about 1-2lbs of boost & lit instantly.
__________________
97 F350 CCLB "Da Bus"
RIP Will Iott
"This ain't no practice run"
  #10
Old 09-06-2011, 03:27 AM
88 Ford's Avatar
88 Ford
Offline
Member's Gallery
Originally Posted by Cat_Rebel View Post
Saw one on a 93 idi in a 69 Ford F100 this weekend. I made about 1-2lbs of boost & lit instantly.
My guess is that it makes 1-2 psi at idle. If not he definitely need to change his pulley!
Registration Verification
Enter the first character in the word "Powerstroke".
Insurance
Please select your insurance company (Optional)
Human Verification
(View-All Members who have read this thread : 381
'99 stroker, 02_powerchoke_F350, 03F250 6.0, 03_PSD, 04smokeman, 04stroker, 150guy, 16yrenthusiest, 1992F350, 1993f250, 19stroker97, 19_A_LT, 1turbo10, 300,000 and counting, 429idi, 444getsitdone, 4duggan, 4x4falcon, 5150Mikey, 530diesel, 6.9performance, 69turbo, 7.3idi-fan, 7.3Mongo, 7.3psd1999, 79Ford7.3, 79jasper, 7_three_stroker, 82f100swb, 84mudder, 88 Ford, 88IDITurbo, 90fordf3507.3, 90idi4x4, 91dirtydiesel, 91forddiesel, 92f350cc, 92IDI7.3, 93 Indirect Injected, 936.4powerstroked, 94.5 Stroker, 94iditrbo, 95f250psd, 95gasser, 96f350psd, 96powerstroker, 96strokeme, 97Stroker13, 99-350, 99blacksuperduty, 99f-250, 99redf350, ajfetterman, Al Mighty, ANIMOSITY, aparker, Arctic Fox, Arly, A_G, B.Warning, BamaBobAlex, Bamboo, bcbsox, bert, bhanger24, bhfarms, BIG JER, Bigandrw, biggreen96, bigjake0524, bigrandy, bigred94, Bigredpoweerstroke, bigsqwez1982, bigwhiteone, BikeMaker, black dawg, black91idi, BlackBeauty96, blackie375, Bmiller5, bng305, bourneenterprises, boxster7614, BP6.9, Bradbilt, bryan.d, BryceB, Buford-61, builditloud, Built4tq, BURNSY_B_STROKIN, Bustedknuckles, cam1911, Case IH Guy, caseih7010, catman, ccambern, cccomplete, cdnf250, Choupique108, chowder48, Clatterindiesel, Cloverleaffarm, clp13294, co04cobra, coalroller3x, coalroller94, codypowerstroke, colt.c.warren, cook03F250, Countryboy07, cowboybootlegger, Cowboyup, crabbelle, CumminsTrader, Cutting-Edge Diesel, Cv0lv0g0, cyberdiamond, dagreendeville, Dana60lover, danby, DarkHorse89, darrell401, dauto87, DaveBey, davey99ps, David N, DeadMan, deezeljunky, dego_red, Delox, Denver, devilman, Dieselboy740, dieselboyf350, diesellaxer, Dieslnevan2009, DirtRider1357, DisturbedS10, DMDP, dmschmidt1200, drh4250, DRT1359, dswhite, dt6999, dunk, dwbierbach, DzlNut, e444, Eric@PTP, EVIL OVAL, ewood, F-25000, f-450coalroller, f250towrig, f350dualie, F550Freak, farmall99, farmer09, farm_boy, Firefighter4hfd, FlatbedStroker, floridastroke, ford2go, Fordfreak4life, fordman2121, fordpower460, Fordzilla11, g.w buffalo, Gman32, goncrazy2003, gone6.0, Grayguy1995, GreyGoose, gsfloor, gsxjay, hag000, hairyboxnoogle, HC Emporium, hcwt, Headcase98002, HELL FIRE, hellerb68, hendricksbus, Hick and Tick, Hyde, hyrk, idshred, IEBahner, ironbarr, Issacdilldine, Ithumpwheniwalk, itsdieselornothing, Jake2345, jam0o0, Jaydiesel7.3, JCart, Jcavers, jdgleason, jerry k, jimmyb, Jjona5, jmsmith76, joedaddy, Jomax, Jonesin, jtlane, junior20762003, juniort444e, JustDiesel, justinh, k8mlp, KCDAXFACTOR, KMakar, kmart164, knkolega42, kqafferz, kyle43335, lawnsafari, LaWrench, LETHAL WEAPON, lil o rinny, lincolncraft, linkfarms, lmfd20, LOSTCAUSEPOWERSTROKE, loudmouth, lubeowner, mandkole, Marinestroker97, martins96, Marty, Matt07, matt25001149, matt92idi, matt_m73, MB97PSD, McFadin(BACON), mdgibson1, Medtrust, mildot, Mini-Stroke..., morefuel, mttrucker, MustangMabry, mwalsh9152, mxredneck, ncovey, NE91idi, NEBR99.5 OIL BURNER, Nelson2011, nick112207, Nitro Blazer, nm351, NMB2, Nos_GTSR, NotStock, NRHX2009, NutFarmer97, Ohnny101, OilBurner62, Olb Blue Beast, Oldreliable, oldschool, optikalillushun, oregon96psd, pa-powerstroke, paretf350, patrickke, pennsylvaniabo, Petro, PJB, pmiller75, poon, Power12, Powerjoke4life, powerstroke cowboy, powerstroke095, powerstrokemike, powerstruck7.3, PPE'dPowerStroke, predator86, PSD-BLACK-CLOUD, psdmike, PsRumors, pullinstroker97, purplepstroke, racer30, RacinNdrummin, rancherstroker6, range91, rashole, Ravenwoodranch, Rdh605, reis1995, rideracelivemx7, RLSCOAL, Rmartin-97, Rocket Pig, rollingcoal69, rpm-inc, Russo2, Rusty-Ford, SAK, sargepep56, sc7.3, screagle07, semomotorsports, Shanediggler, Shaun Lindmark, shmokenpstroke, silent64, sixshooter, Skyler, smith7.3, smokey bronco, smokey7.3, Smokin LB7, Smokin444, smokindiesel2, smoking69, smokyidi, sootieoil, southtexasidi, sprayjock, Stacked95Flatbed, stackedstroker, Stacks92, StandAlone, ste2, steinerr, stevensjustin87, stoker04, Strictly Diesel, stroke931, STROKENPA, Strokin96, strokinaz, studded 6leaker, Super08Duty, SuperDuty73, t4050nh, tbirdscott, tedsxb, theSLEEPER, TheStroker, thewoodman, Tiewire, tjctransport, trackspeeder, Tugboat2060, Turbill, turbolab, UNCOOL, Utah7.3, vinnman87, vista461, wanabebig, wannabstrokin, WannaRollCoal, wbrett1027, wint, wjamesm, wood7707, Woody35, worm5932, Worstenemy453, xrxmxcx, xtreamracer8, yogr, z0650, Zrock
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
