im looking to build a custom 2 gauge pod and set it in the little cubby hole in the dash just under the radio. where can i find supplies (mainly the 2 1/16" rings) to build the skeleton of the mount? or would it be cheaper/ easier to build my own?
make it out of foam, wrap it in fiber glass, coat it in bondo, spray it with paint, install, smile.
for where your goin to put it, on the fiberglass stage, you should intentionally make it about 1/8 to small. that way it fits. then make up the gap with the bondo. the bondo will form fit/contour easier than fiberglass, and sand a whole hellava lot easier.
107.4K members
