Ok Gentlemen I will let you all know-->I am very ignorant when it comes to leaf spring knowledge... Hence the reason for my questions...
Since a 4in lift is out of my price range right now, plus the price to have it installed... My problem is my drivers side front is 1in lower then the passenger side... Looking at the front of the truck from 10yards away, it is very obvious...the truck looks drunk...
I have just chosen to upgrade my stock leaf springs with replacements... To help with handling and towing of the families 5th wheel and other work trailers...
Right now I have really have no idea what the stock spring ratings are for the 01 F250 PSD... My rear leaf springs have 6 leafs...The front has these very puny 2 leaf spring set up... Ok... I was recommended to this company and their products and great service... If those who have time, could you take a look at these leaf springs and give me your opinion and advice...
Rear: 6 spring replacement
1999-2007 Ford F250SD, F350SD 2wd 4wd - Leaf Spring (Rear - 6/1 Leaves) - 43-1263HD | $184.95
Rear: 10 spring replacement-would these be a good upgrade?
1999-2007 Ford F250SD, F350SD Chassis Cab 2wd 4wd - Leaf Spring (Rear - 10 Leaves) - 43-1265HD | $206.95
I also have plans on adding a set of Timbrens on all 4 corners to help with leveling of the F250 during towing...
Front:
1999-2004 Ford F250SD, F350SD 4wd - Leaf Spring (Front - 2 Leaves) - 43-818 | $110.95
What are ideas to do with the front end leaf spring setup to help keep the front leafs from sagging over time... I know the 7.3L is very heavy...
Any Thoughts or advice would be appriciated... Looking to do the replacement next spring...
Front:
