If someone was to replace the carrier in the rear with a new one, just by removing the Ring Gear, does everything have to be shimmed again etc ? Simple task or no ?
I would set it up like it was and check your gear meash and blacklash. I set mine up by hand, for customers i will use MICS tho. Even tho its a machined part it only takes a few thousandths to throw every thing off. Its not hard just time consuming if you gotta shim it
Never done it, great I'm not gonna mess with that then right now
