ok here is the truck. 2005 f350 6.0. first off i don't want togo to big because i tow things some times. the other thing is in the winter here in CT the stock rims will have to go back on. and a big lift with stock rims and tires looks bad. and what the bolt pattern on this 2005? 8 Lug, 170mm i think? and what offset will fit the best? if there is any other rim tire lift combo you think will suite me better let me know. thanks
if i go with 20x10 XD Diesel Chrome Wheels with Nitto Terra Grappler 295/60/20 All Terrain Tires can i get away with just the 2.5 level kit?
or even some thing like this?
2005-2011 Ford F250/F350 Super Duty 4x4 - 2.5" Suspension Lift Kit
That tire translates to roughly a 34x11.5, so technically its not even a 35. You will be able to fit it with just a leveling kit but you will probably have to trim a little depending on the offset of the wheels. I can only get about 1 and a quarter turns of the wheel and with a crew cab long bed, I will admit it can be a pain when it comes to parking. But I am willing to deal with that because I'm not cutting up my fenders.
If it were me I would go with the zone 4" kit, those kits are very inexpensive and the ride quality is awesome! And then depending on your exact look you want, you could run a strong 35", tire if you wanted too, without clearance issues.
I went with a 305/55/20 on my 05 F350 4x4 Crew cab with a leveling kit, and it was fine. I also have a zone offroad all spring 4" lift kit with Bilstein 5100 shocks and steering stabilizers. It is a very nice kit. That one is in my sig on my 09.
all right thanks. ill get the zone 4 inch then. i'm paying a buddy to install it is there any thing i should do at the same time to keep my cost down? any thing else i need?
looks like i should get the Carrier Bearing Drop Kit too.
all right the 4 inch kits ordered from zone. with the Carrier Bearing drop kit and longer u bolts. $961. shipped to a business address. would have been $50 more to my door.
now i need some stock 20 inch rims to put 35s on for winter. or a set of 35s to go on my 18s. i will get 20s or 22s when winters over here. then ill know if my tucks ready for a bigger tire or stay with 35s.
can any one suggest a good 35 for the road and winter driving? thanks
If you didn't already read one of my other posts (newb qustion posts) my truck has the 4 inch zone lift kit on it now. Here is one of the rim and tire set I'm about to settle for. I can't really find any thing I like better. I kind of like the 951 ( or what ever they are) moto metals but I don't like that the lip has the spokes all the way down them. If I go with this rim what back spacing Should I go with? At least if I know what I need for back spacing I can pick a rim out when I see some thing I like. Thanks
heres a link with two different tire options
$2,649. with street tire or $2,599 with mud tire,
Will this terra grappler look like a big street tire? If so I don't want them.
If you have any trucks in your area take a look at them and ask what there backspacing is. I run 5 inch backspace wheels on 2006 axles and the tires stick out quite a bit and can hit the bumper or wheel liner in certain conditions. With you running a 4 inch lift and 35 inch tires it isnt very likely they will hit though.
If you would prefer them to stick out less, look for wheel offered in 5.75 inch to 6 inch backspacing.
Most people seem to run 5 inch backspace wheels but its hard to get an idea how far they set out with pictures on here versus in person.
Ok. Any one else want to put there back spacing and a pic of how much it sticks out?
What is -24mm? I went and tried to convert that and it said -0.9..... Thanks
If the measurement is in metric (has 'mm' or 'cm' after the number) it is offset.
If the measurement is in imperial (has " after the number) it is backspace.
My backspacing is 4.5" and my rim is 12" wide so that is 7.5" going away from the mounting surface. My tires stick out roughly 3.5 inches so that means it takes about 4 inches or so to be flush with the fender.
and that google link is funny. i seen it before but never been hit by it till now. i hate to ask all kinds of stupid questions but its hard for me to search the net all day and not find out what i'm looking for or be mis lead buy people who don't really know what there talking about. i figured you all have the same truck and could help out with a quick answer.
you happy with the diesel's im going to follow the same path before summer
