p2285 ??? - PowerStrokeNation : Ford Powerstroke Diesel Forum
Go Back   PowerStrokeNation : Ford Powerstroke Diesel Forum > Super Duty 1999-Current > 6.0L Power Stroke Technical Info
Register Members List TimeslipsPhoto Gallery Calendar Auto Loans Sponsors Becoming a Sponsor Mark Forums Read Auto EscrowInsurance
Thread Tools Display Modes
  #1
Old 07-11-2011, 10:39 PM
kh_strokin07's Avatar
kh_strokin07
Offline
Mean Green
Member's Gallery
p2285 ???
my truck has been throwing fits the past two days and this morning it started up just fine idled good until i put into drive and it reved up then just died on me.... it took five or six long cranks to get it started and it did it again this evening after work.... and had no power at all,, it idled really rough and cut off going down the road and the code it threw was p2285 said injector control sensor ck t low.... does that mean the icp sensor is bad or something else cause i replaced that sensor about a year ago
__________________
2006 f-250 Harley davidson, stock everything
Reply With Quote Quick reply to this message Go to the top
Old 07-11-2011, 10:41 PM
CTC DEEZUL's Avatar
CTC DEEZUL
Offline
Hood Rich
Member's Gallery
Send a message via AIM to CTC DEEZUL
Re: p2285 ???
Has the pigtail harness going to injector been replaced? Sounds like the IPR is over compensating for a ICP system leak, possibly the HPOP going out.
__________________
NWI Coal Rollers Association
Local 444- Rolling Coal Teamsters
via Beans Toonz
DI SS Up-Pipe
GTP38R
  #3
Old 07-11-2011, 11:46 PM
kh_strokin07
Offline
Mean Green
Member's Gallery
Re: p2285 ???
yes i replaced the harness but i looked at it yesterday and the clip had broke off the plug on the harness. what does the code mean when it says "icp sensor ckt low"... what are symptoms of a bad HPOP?
  #4
Old 07-12-2011, 02:18 AM
CTC DEEZUL's Avatar
CTC DEEZUL
Offline
Hood Rich
Member's Gallery
Re: p2285 ???
that either a circuit problem, or that there actually is a ICP issue, usually its a P2284.... Bad Hpop is lasy starts, hard time starting hot, occassionally dies, etc
Have you had your STC fitting updated yet?
  #5
Old 07-12-2011, 02:22 AM
bismic1
Offline
Member's Gallery
Re: p2285 ???
He has a 2004. I would bet on a developing HPOP issue.
__________________
Mark
  #6
Old 07-12-2011, 02:59 AM
kh_strokin07
Offline
Mean Green
Member's Gallery
Re: p2285 ???
tonight started right off... it has no starting problem. but it tried dying on me and has hardly any pedal, no power at all and something new popped up when it was cutting out my glowplug light and my cruise control light was flickering...
  #7
Old 07-12-2011, 07:36 AM
bismic1
Offline
Member's Gallery
Re: p2285 ???
How's your batteries? Alternator? Wiring and grounds?
  #8
Old 07-12-2011, 12:09 PM
CTC DEEZUL's Avatar
CTC DEEZUL
Offline
Hood Rich
Member's Gallery
Re: p2285 ???
I'd advise to pull the hpop out and if it has the older STC fitting, just go ahead and replace the entre pump.... One of those, while your there things
  #9
Old 07-12-2011, 01:31 PM
strokin6L's Avatar
strokin6L
Offline
Member's Gallery
Re: p2285 ???
the P2285 code is for a bad icp. I just replaced one about two weeks ago with this code. I ended up putting a new pigtail harness on it to. A bad ICP sensor will make the truck surge, idle real rough or have bad starts and even make it stall.
__________________
2004 F-350 SC 4x4 6L....little bit of this...little bit of that
  #10
Old 07-13-2011, 01:07 AM
kh_strokin07
Offline
Mean Green
Member's Gallery
Re: p2285 ???
its p2284 icp circuit low... what is circuit low?
Human Verification
(View-All Members who have read this thread : 103
03-6.0whistler, 04La4iat, 04MT, 05cwa, 06-6.0 stoker, 06f3506.0, 06f350stroker, 06regcab6.0, 2005F350, 7.3stroker97, acplowboy84, adamquintonMDP, Allwhite, amdriven2liv, andrewv_24, asims9, Bamfuav, BBowden73, BCPSD, Bignbadbelair, bismic1, bluemountianpowerstroke60, bobcat743, Brent1, Brian Cox, CoryC, craig031600, Critter62675, CTC DEEZUL, dalpilot, Daltonf, Dangyo, dbarnett42, DeereMan83, dieselmac, dswish, elky57, farmerboy93, fireanchrome, fordboy11, george german, Gibrid4x4, Gnarkle, gtmustang00, Harley Strokin', hill_billiez, IcyTimes, infennerator, IWANAFAST6.oh, jake1086, Jaredward18, Jason.Horath, JasonJ21, jaybuller, Jeff M, jimanold22, jmyrkle, jratoms, Kenobi27, khantroll, kh_strokin07, kpasichnyk, Krisco, ktmrydr686, LiftedBlackHD, matts05f250sd, MT Pockets, mttrucker, muddynoll, namerritt, needalaugh, paranoidredneck, PDEMICH, petesripper, POORBOY1964, Pops 03DEX, powerstrokedub, POWERSTROKE_GOD, RCode94, Rick C, rickvm, rockinamullet, Shef, silent64, Sixpointsl0w, smokenblack, strokefreak, StrokeThis34, strokin6L, superdutycummins, superx, suprdzlduty, thedodd, Thunderheader, Tim @ P.I.S., toolmangary, TXBammer27, USMC6.0, webb06, wesstcoastslider, whitestroke, willholl79, Zmann
Forum Jump
Powered by vBulletin® Copyright ©2000 - 2015, vBulletin Solutions, Inc.
