| Register | Members List | Timeslips | Calendar | Sponsors | Becoming a Sponsor | Mark Forums Read | Auto Escrow | Auto Loans | Insurance |
Thread Tools | Display Modes |
#1
Fuel pressure/test port
Hi, does anyone know right off hand, on a 2004 6.0 what is the type and size adapter needed to use in the test port on the engine mounted secondary fuel filter housing, to attach a fuel pressure gauge sending unit? I'd like to go ahead and buy the parts, so I can just take it apart and do it all at once, and not have to find a ride to run me all over town looking for parts. I have the blue spring regulator upgrade, but I'm getting a code that says Injector Control Pressure Low (or something worded along those lines) so I need to check it at all throttle levels.
__________________
bigf350sd: 04 F350 CCSB 4x4 6.0 leveling kit on 305's, MBRP 4" muffler with no cat on otherwise stock exhaust, Blue spring regulator upgrade, ZooDad mod, SCT tuned, Edge Insight CTS Other stuff coming soon, including tunes from Matt @ Gearhead's, STUDS, full EGR delete, real exhaust, and bypass oil AND coolant filtration. |
| Sponsored Links | |
Advertisement |
#2
Re: Fuel pressure/test port
Fuel pressure will have little to do with your ICP. The ICP monitors the High Pressure Oil pressure in the rails.
$8.00 fitting What you really want, $40
__________________
'06 F-350 6.0 Excab short box 4X4 Lariat FX4 Bulletproof oil cooler w/cold weather package, blue spring, EGR delete, CCV mod, edge insight and autometer gauges
#3
Oh, ok on the ICP. I should have known that! As much as I've learned about sticking injectors and that they work on oil pressure, etc... Guess I'm losing my mind in my old age...ha ha
#4
And thanks for the links as well.
#5
why the 40 buck piece,,,the adapter alone screws into the housing then the sender without all that extra line laying across the motor,wires,other hoses maybe shorting out stuff or rubbing holes in things,or is there more to that line and tee setup
#6
wonder if anyone has tried it without the line, then with the line to see if any diff in presures?
#8
No difference in pressure. Take a good look at the sender. See the size. Do you want that hanging on the fuel bowl and vibrating? I think not.
I believe that the sender may touch the rad hose as well.
__________________
I hear that Dodge is giving you a puppy with every truck you buy, so you'll never have to walk home alone again. 2007 F250 6.0L PSD Lariat 4X4 - Dieselsite Coolant bypass Filtation -Bilstein Shocks-Blue fuel pressure upgrade spring-Rough Country Duel Steering Stabilizer-Fumoto Oil Drain Valve-HFCM Water Separator Drain Plug Upgrade-ARP studded |
#9
does anyone know for a fact it will touch the rad hose, theres several sensors on,around this engine, all right on this engine with vibrations going on,,id be more worried about the vibrations on that 40 dollar hose than a sensor,whats that sensor weigh 6oz tops with a wire on it,,i was asking to see if another reason to use that high dollar setup to make presure work,if not 8 bucks looks better,on paper anyway.
| Thread Tools | |
| Display Modes | |
