1996 7.3 cruising at 60 cruise control on it started sputtering like the tank was dry and then died. Started it back up and it dumping fuel black smoking. It also way down on power. Checked the filter and it good. Please help I'm sitting on the shoulder
Check the screen on the inside of the fuel bowl on the driver side. It may be plugged.
After thinking about it and you said its pouring black smoke then I'm gonna guess and say you have a hung injector and its just dumping fuel into the motor. Careful it can cause the motor to lock up.
