My 6" springs have dropped almost 2" in less than 11 months. I am really dissapointed in this as now i am having clearance issues with my 37's I need some measurements from some of you with a 6" lift. What kind of space do you have betweenn the top of the spring and the frame on the front axle. also from the ground to the top of the wheel well would be great if you are running a 6" and 37's.
I hear they have a lift time warranty. I spoke to them on the phone before and it is basically you'll get a new set.
Call and get the new set shipped out.
from what i have found out. Its not sagged. Its setteled. The ride height i have now is the same as 3-4 others with thier 6" spring. Nothing wrong except that they setteled a lot more than i would have expected.
SO basically on initial install you had closer to 8" of lift and they have now settled to the 6" which is what they were suppose to be spec'd to. SOunds like they know what they are doing but I too would be a bit taken back with a2" drop if I was not sure. I guess it pays to measure from the initial install so you know where you are at and give you a better idea whats in store.
