Ok I installed my PMF traction blocks last night. They have 5 alignment adjustment holes in the top of the block. I have it in the middle one (Number 3) on both sides So the axle should be even on both sides right? No the passenger side is sitting further back than the drivers side. I looking under the spring and saw where the stock blocks were sitting (had a yellow mark on the spring) My new blocks are sitting perfectly along that same stock block mark.
I have double checked that I have it in the middle alignment hole on both sides and I do. Also it seams that the steering wheel is turned more to the right now to go straight. I can adjust that easy.
I took off my Stacked block combo. It was the stock block and a 2.5" block. The PMF blocks are 4.5 tall. So the PMF is .5" taller. But that should have no effect on the steering and the right and left side differences or should it?
