Ok, so it seems like I read somewhere that there was a way to use a modified t444e front cover that originally had the gear driven ps pump into a dual hpop set up.
OK, so search owns me, just found a thread about diy gen 3 big oil. Looks like way more work and money than I have to invest at this time, guess it's off to the storage shelf with this one for now LOL
The Stealth SRP1 pump is designed for the 94.5’ to 03’ 7.3L Powerstroke engines. The Stealth SRP1 pump is a “Stock Replacement Pump”, SRP1, that will give you Stage I performance in a stock pump housing! We have addressed all of the stock HPOP housing flaws while at the same time increasing internal displacement by almost 50%! This is an increase of over twice the displacement that our competitors are offering in their pumps! These new pumps have all new internal components for a reliable operation. Inside these new pumps there are all new larger billet pistons combined with a new 18-degree billet swash plate that still retains stock reliability while increasing displacement by almost 50%! With the new larger pistons and new swash plate we have managed to increase displacement to 10.45cc vs. the stock 6.8cc or 7.2cc pumps. All pumps are designed with dual ABEC-5 ball bearings for added stability during operation instead of a rear bronze bushing like the stock pump late model pump uses. All of the snap rings, o-rings, and seals are new. We have machined the 3 high-pressure output ports from #6ORB fittings to #8ORB fittings resulting in twice the thread surface area, which means no more stripped or blown out fittings. We have also machined the edge filter plug in the bottom of the pump and taken it from a #3ORB fitting to a #6ORB fitting resulting in twice the thread surface area. We also machine some of the internal passages to ensure proper flow in and out of the pump. These new Stealth SRP Stage I pumps housings are bead blasted and coated with a ceramic base high temperature paint. The front mounting gasket surface area is re-machined flat to ensure a leak free installation. All of our new Stealth SRP1 pumps are rigorously tested to full pressure and full rpm on our test bench for 30 minutes to ensure optimum efficiency and performance before they leave our shop. The Stealth SRP1 comes with everything listed above and is also covered with a 1 year unlimited mileage warranty.
No plans on doing this anytime soon gang, I lucked up on the med duty stuff for free, so I thought it may be a cheap upgrade, If I do anything soon, I'll be sending Joey one of the 3 pumps I have for him to have his way with.
Sure am..duals obsolete..increased shearing of oil etc..with the Stealth line of pumps no need for Duals or their problems at all.
107.4K members
