You would have to check the spring codes.....one could be a heavier spring than the other. Or they could be the same. All depends on what package the truck was equipped with.
I didnt realize there were different spring codes for the f350's. Same truck up front, just rear suspesion is different, I thought. Maybe the 2011 are a higher rate, being a bigger motor. Then again I dont know if it weighs more.
