Best way to go about lowering my lift 6in now wanting 4.5 don't like how much space is in between tires and wheel Wells. Any suggestions would be greatly appreciated!
what brand lift do you have? If the front is shackles, get smaller shackles. If it is springs, remove one of the leafs (some packs such as pro-comp have a 1/2 spacer on the bottom of the spring pack-they are removed for gas applications, and removing it on a diesel will lower you about an inch) Is the rear a block lift, or spring lift? PICS! also, going down 1.5 MAY require a different track bar drop bracket or adjustable trak bar. Get yourself some BIGGER TIRES!
thanks guys will prolly end up going to 37's next time around!
