voltage is 11.8 while engine is off and 14.3 while its on, lights are wired fine, this just started this morning. Ill look into the flasher, i hope thats the problem, i hear its a cheap fix
I gotta agree on that one.. I'd be checking voltage drops an' stuff across the circuit before my $5. flasher turned into an $85 multi-switch and the problem still wasn't fixed..
hey thanks for the input guys, i did some more research and found the problem, the problem was the L.E.D's, I have one for each light and the voltage being drawn from them was so low that the blinker didnt have enough juice flowing through it so it acted like all lights were burnt out, I bought four 3 to 4 Ohm resistors to act like it needed more power and it worked immediately, all my lights are working correctly now- here is a pic i took to show what i did
