ive had new bdp stage 2 injectors for about 10k mi
i have AE scan tool what should i look for
it idles great cold gets hot and dies
ipr or tps? what controls idle?
thanks
Did BDP tune the chip for single shots or was it done prior to the SS being installed?
Jody did my tunes and my 80E shifts a lot faster than the 60 or 40 Tow so that is something that the tuner can adjust but in your case, you have to send it back to them for fixing. Assuming nothing else is wrong.
Not sure how to do it without a scanner but perhaps you have a Throttle Position Sensor issue? Maybe you can find the circuit diagrams and see how to do it? On my other car, there are 3 wires. Ground, Feed to ECM and Reference voltage. What I would do is get the Feed and ground wires and hook them to a DVOM and with the ENGINE OFF, slowly depress the pedal and see if there is feedback change? Also with a scanner, I might be able to see what the ECM sees.
another symptom, from 0-1/4 throttle it runs very rough at any speed
from 1/4 to full smooths out and runs very well
im going to run scanner today, will give results soon
new injection pressure regulator
new icp sensor
new throttle position sensor
