If both tiresbare getting chewed up on the inside I would not be so sure they have your alignment is correct. Ford has HUGE tolernaces in their specs. Get the print out and compare it to the exact specs not the range. If its a 4x4 itbcould be a unit bearing/s. If there is any binding or noise when you spin a wheel there is a good chance they are going. If there is any movement when you push pull on the tire they are already gone. Worn tie rod ends coukd alos be an issue.
If this has been an issue that did not pop up until you got new tires even if it did not start the day of it could be the tires.
truck is at the stealership right now, they say my vibration is the driveshaft. It needs to be replaced at a 1200 dollar bill.
I had my tires balanced and rotated at discount tire before i took it into the dealship, the dealship said they had to break two tires off the rim and re seat them to get the tires to balance.
I have no idea why the driveshaft would be bad. havent done any serious off roading, i havent been in a accident or hit anything. Could the drive shaft be balanced by a shop or am i going to be stuck buying a new driveshaft?
make sure your hubs aren't staying engaged if you have the vacum operated hubs. it could be an axle u-joint. take your driveline to a actual driveline shop and have them check it out. to rebuild it is around $300-$400.
