Had a u joint goi g out and cannot get the front axle bearing off and ideas or a write up on it would be great. The dust shield on the back is about rusted solid could that be preventing it.
Its probably just the axle seal for the back side of the unit bearing. Turn the knuckle to one side and hammer on the back of the seal to push it out. Youl need a new seal.
I usually air chisel on the studs from the backside, carefully from front to back and usually it will walk out. Small pointed chisel right on the center of the stud.
107.4K members
