Exactly like the title says.... what would you guys recommend turbo wise? Using a 400/600 inj with a cam and P/P heads and headers. Not street driven. Strickly for all out pullin.
I have an idea but curious to see everyones recommendations.
I kinda understand that.... but not sure on the mwe groove part. Assuming it is something that will allow air into the turbo but not through the bushing?
And you should look at the rest of the rules.... Very broad and open.
Good info right there. Def something I will look into. What about something a lil bigger than an 82? Or would that be pointless cuz I would have to bushing down to a 3.2 inducer? I was thinking more like an 88 or even a 95.
HX82s come in inducers of 4.4 to 4.6" without getting too much custom done.... so if a 112mm inducer isn't big enough.....
And I am not saying that you need an HX82 exactly - my point was pick something that "fits" the rules as best as you can and picking a stock 3.2 inducer charger is not it.
HGood info right there. Def something I will look into. What about something a lil bigger than an 82? Or would that be pointless cuz I would have to bushing down to a 3.2 inducer? I was thinking more like an 88 or even a 95.
Didn't know that about HX82s. I guess I am askin how big would be 2 big?
I was looking at using a s4 turbo for both the primary and the secondary as they seem like strong turbos. I know most guys have ran a 66 as their secondary turbo but I was thinking more like a 71. Esp since this will be for pullin only. But then I was thinking that since my primary turbo is limited to 3.2 the 71 might be to big.
Short bus seems to have one hell of a compound setup with the 95 but I doubt his is bushinged down to 3.2.
Edit: and I know a stock 3.2 turbo isn't going to cut it and as vague as my rules are I wanna exploit them as much as possible.
I'll vouch for how strong Luke's rig is And I know its stronger now than when I had it at my place.
Don't let the bushing thing make you believe that there will be any noticable difference in how it runs - its all in HOW its bushed and setup.
