Hey guys,
I just found that my passenger side front axle bearings and hub are shot. What I needed to know is; is the outer stub shaft needle bearing included with a replacement hub assembly or is that another piece that needs to be added? Also, is there another bearing and seal on the u-joint end of the inner shaft?
Right now, the u-joint is setting on the ball joint stud, and I can move it up and down at least 1/2 inch.
I removed the guts from the hub lockers on both sides. The driver's side seems to be ok. I'm guessing it was serviced in the past since the dust shield is gone from that side.
I still plan on rebuilding that side as well, just to be on the safe side.
Thanks
Thanks
