Mad Jack Racing
Go Back   Powerstroke Nation > Super Duty 1999-Current > 7.3L Power Stroke - Aftermarket & Performance
Register FAQ Members List Calendar Timeslips Videos Sponsors Becoming a Sponsor Search Today's Posts Mark Forums Read
Closed Thread
Thread Tools Display Modes
  #1
Old 12-11-2007, 09:49 PM
4x4 Nut
Offline
Member's Gallery
Completed Project Pictures
Hello. I have been informed of this site by a few different people and thought I'd join and post a recently completed project we have built. It's called Dominator and is an '02 Excursion Limited 7.3 PSD.
It has 30" of lift at ride height and is adjustable from 25-40" via air ride. The engine has an estimated 500 RWHP. Here is a list of mods done on it. Many of the parts were purchased through some of the sponsors of this site.
Engine
7.3L Power Stroke Diesel
Forged Rods in place of stock Powder Metal Rods
ARP Head Studs and Main Studs
Balanced Rotating Assembly
Comp Cams Valve Springs
Fluidampr
Terminator Engineering HPOS
Dynomite Diesel Performance B Code .0075 Injectors
Turbonetics Ball Bearing Drop In Turbo with High Flow Exhaust Outlet Housing (ceramic coated)
Non Exhaust Backpressure Valve Turbo Pedestal
Spearco 6.0L Intercooler
Diesel Power Products Intercooler Hose Kit
ITP Diesel Regulated Fuel Return Kit & Boost Annihilator
FASS Fuel System and Supply
DP- Tuner, Custom Files by Jody Tipton
MBRP 4” 304SS Cool Duals Exhaust system w/ 5” dual wall tips- custom made for this truck by piecing together the system with universal mandrel bends and then sending the mock up parts to MBRP in order to be made in Stainless Steel. The whole dual system is made up of only 4 pipes- downpipe, mid pipe Y, and both tails.
AFE Stage 2 Intake System
Black Widow Ceramic Coated Bellowed Up Pipes
Ceramic Coated Exhaust Manifolds
Intake Air Heater Delete
Auto Meter Instrumentation
Pyrometer (on steering column), Boost, Tranny Temp, Axle Temp, Transfer Case Temp (A- pillar)
Transmission
Built by John Wood Automotive
Billet Torque Convertor
6.0L tranny cooler
Torque Converter Manual Lock Up Switch
Tail housing mounted parking brake.
Driveline
SCS Gearbox 4WD quick change transfer case w/ air shift front disconnect- uses factory dash mounted 4WD selector to operate and has indicator light on A pillar gauge mount.
1480 Spicer driveshafts
2.5 ton Rockwell Military Axles- 6.72 gear ratio
2” Ouverson Engineering and Machine Violator Series axle shaft kits
Ouverson Ultimate Lockers (front and rear)
Ouverson Billet Deuce locking hubs
4 wheel disk brakes w/ 4 wheel ABS
15” rotors with front 4 piston calipers- brake system built by Kat Kustoms, LLC
Suspension
Kat Kustoms built custom triangulated 4 link- 30” of lift at ride height.
Adjustable height 25-40” of lift
Firestone Air Springs on trailing arm mounts
Bilstein Black Hawk 9300 bypass shocks
Custom built steering system
Tires/ Wheels
54” tall Michelin 24R21 XZL truck tires
21x18 Stazworks 2 piece beadlocked wheels
Other
On board air and bag control system
Filled, Smoothed, and Painted Frame
’06 Harley Davidson front conversion
Kat Kustoms auxiliary head lights and tail lights
Kat Kustoms built Pneumatic fold away steps at each door
Train Horns
I'd like to thank guys like John Wood, Jody Tipton, Ross @ Dynomite, and Kevin @ Black Widow for helping with advice on setting up the engine with proper parts. The truck sure does run and drive nice.
Go to the top
  #2
Old 12-11-2007, 09:51 PM
jvencius's Avatar
jvencius
Offline
Peon
Member's Gallery
Re: Completed Project Pictures
Ugh--that thing is hideous.
Go to the top
  #3
Old 12-11-2007, 09:56 PM
03f3507.3's Avatar
03f3507.3
Offline
Member's Gallery
looks to be very well built congrats on that but just not my style either...
Go to the top
  #4
Old 12-11-2007, 09:57 PM
mattymx's Avatar
mattymx
Offline
<----Colin Banks
Member's Gallery
WOW! That thing is huge!
__________________
Typer of the world famous "ASS LUBRICANT" typo
><> MY TRUCKS<>< YouTube Vids
Go to the top
  #5
Old 12-11-2007, 09:58 PM
Cat_Rebel's Avatar
Cat_Rebel
Offline
Team Poorboy Mechanic
Member's Gallery
Send a message via AIM to Cat_Rebel Send a message via Yahoo to Cat_Rebel
Nice job
Is that thing street legal?
__________________
RIP Will Iott
"This ain't no practice run"
TPB#22
Originally Posted by Gray 03
i would hook up with a black midget
Go to the top
  #6
Old 12-11-2007, 10:01 PM
BFD99's Avatar
BFD99
Offline
I want a 6.4
Member's Gallery
Send a message via AIM to BFD99 Send a message via MSN to BFD99
i like! although a little high for me, but i do like it!
__________________
Dex
2006 2500 Ram QC SB 5.9L 2wd
2004 F-350 Dually 6.0L CC LB Dually 4x4
2010 F-350 Dually 6.4L CC LB Dually 4x4
Thanks to Doug at Gogodiesel.com
Go to the top
  #7
Old 12-11-2007, 10:11 PM
Haul_n_horses2's Avatar
Haul_n_horses2
Offline
Member's Gallery
What a waste of money. Whatever floats your boat, I guess. Love to see it off road in the rocks with the center of gravity. I would give about 30 seconds before it is on it's lid like a tortoise. Why wife would say, " Trying to compensate for something?"
__________________
2002 F350 Lariat CC 4x4 4.10 DRW, with "the ultimate towing setup!": Nov 30, 1999 engine with Fluidampr, Melling LPOP, 910 springs and ARP headstuds, DP-Tuner, DI regulated return, AC singles with 80% over EDM nozzles, BTS dual HPOP, H2e, Spearco 6.0 IC and BTS tranny .
Go to the top
  #8
Old 12-11-2007, 11:09 PM
mustang_gt_350
Offline
Member's Gallery
I don't think that would even fit in if it was in West Virginia....
welcome to the site
Go to the top
  #9
Old 12-11-2007, 11:18 PM
PTSUPERD's Avatar
PTSUPERD
Offline
SUPER MODERATOR
Member's Gallery
Engine
Fluidampr
Transmission
6.0L tranny cooler
Driveline
Suspension
Tires/ Wheels
Other
Train Horns
I'd like to thank guys like John Wood, Jody Tipton, Ross @ Dynomite, and Kevin @ Black Widow for helping with advice on setting up the engine right. The truck sure does run and drive nice.
I dig it! Kat Kustoms doesnt have azz anything!
__________________
2001 Chevy Tracker. Auto. pwr steering. power brakes. tinted windows.
Go to the top
  #10
gregrob's Avatar
gregrob
Offline
Member's Gallery
Did you really just quote all that?
Go to the top
Closed Thread
(View-All Members who have read this thread : 193
00PSD1, 03f3507.3, 14"stroke, 1snotrocket, 389SixPack, 4x4 Nut, 69W900A, 7.3 King Ranch, 94ttss, 96strokerwg, 997.3PSD, 99RoyalBlue, AlaskaRedneK, AMB, Arisley, B18B1LS1, BADASS03SVT, badluck_early99, BDS, BFD99, BIGLARRYS03, bigrpowr, BigSlick, Blowby, blowinblack, BockDiesel, breyrw, brokexj, Bushwakd, Camptoboat, cemeyer, chasespeed, chrisreedtn, Cmonster, comfi, coope3, cota, Cppr_Busa, crack_7.3, crfracer, CSIPSD, cvdenson, D2HP, dag, dblamp, DCSpecial, Dieselboy, DieselBrad, Dieselgeek, dieselsmoke, Diezel Dawg, DOMN8R, DoubleL, DSTRBD, dstruble, dunesday, dustinjean, Dysfunctional, ELKHUNTER, EMD_16_645_E5, Fast_Ashley, fbilly420, Ford850, forddieseltweek, FordF250Stroker, fords4life, FORDTRANSTECH, Fordtruckman21, glamis_dave, godofdew11, greenbeast, Haul_n_horses2, he_likes_truck_more, Hiflyer746, highfive, HitchHiker, Hooch, Hoss, hotstik, ijuslikefords, imelmo, Imjosh, jebsurf, JeepPuller, jeromejcp, jibmaster145, JJKpowerstroke, joediesle, JoJon, jsf350, Just Stroken, JuststrokeIT, jvencius, KAC1023, kip4234, Klutch, lildevil02, lownslow, Madvan, mad_matt, Marinepowerstroke, mattrac, mattymx, mike01b, MILFORD, Millheim, morepower02, Mr. Bob, munster, mustang_gt_350, npen, NyCowboy87, Oilfield_Digger, Orezona, outlaw5.0, panhandle_redneck, Phatbulldog, Powersmoker, Powerstroke Racer, PowerstrokeJunkie, PowerstrokeKid, Powerstrokin444, PSD 2004, PTSUPERD, QtrHorse, Radarman, RAMPAGE_F350, rebelchevy02, REtsitty, Reubine, riverjet, rob10970, RockinJW, Rockrunner86, rpm-inc, RSieck, Rustler, samdust, Sanger, schmity, sgleshot, shawn goldbach, sheboyganjohn, silverslug, SinisterDiesel, slowleak, SmokeWagon, smokin dually, smorris, southmike, southsideservz, spareparts, spectra, speediseverything, squeeks, srlaws, Stroked95, StrokerTurbo7.3, strokin_early_99, strokin_hard, Tenn01PSD350, TerminatorEngineering, THEDIESELMAN, theSLEEPER, Tim @ P.I.S., tkdbf350, Tom S, trackspeeder, TrailerHauler, TRX370r, Turbo99, two-rocks, txpsd, UNBROKEN, UNCOOL, UNLIMITED_DIESEL, vapstroke, VC-Racing, white_stroke, wjamesm, wooner, yamt03
You may not post new threads
You may not post replies
vB code is On
Forum Jump
Unlimited Diesel
Powered by vBulletin® Version 3.6.7
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
