2003 Super Duty rear end vibration - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 27 (permalink) Old 12-26-2010, 01:07 AM Thread Starter
Question 2003 Super Duty rear end vibration
2003 f250 Super Duty has a bad vibration in the rear end at highway speeds (60 plus). We thought it was the new tires we had put on... but we are on a third set of tires now and still no change. The weird part is that the truck will shake bad for a few minutes and then smooth out for thirty seconds or so. It tends to smooth out around a bend on the highway. We thought maybe it had a bent rim, but if that was the case it wouldn't smooth out at all.?.? Any ideas on whats going on before we take it to the Ford stealership?
RedHorseFarm is offline
post #2 of 27 (permalink) Old 12-26-2010, 01:24 AM
Re: 2003 Super Duty rear end vibration
jack it up and check the ujoints and carrier. I bought a truck once from the local car auction that others didnt want because of a bad rear end. I drove it home vibrating and all. Jacked it up and found a bad ujoint. Problem sovled for me.
2011 6.7 F350 CCSB BLUE SWEET RIDE
1996 F350 BABY SWAMPS AND TS, FLAT DOWNPIPE
semomotorsports is offline
post #3 of 27 (permalink) Old 12-26-2010, 03:38 AM Thread Starter
Could it be a u-joint even if there's no clanking noise?
post #4 of 27 (permalink) Old 12-26-2010, 04:46 PM
yes all I had was a vibration, no noise. You cant tell if a ujoint is bad useally unless all the load is off the driveshaft so you have to jack it up.
post #5 of 27 (permalink) Old 12-26-2010, 05:05 PM
scott2001's Avatar
whle you under there go ahead and check all the joints, do the wheel trick.
2008 got a new flex pipe installed. S-b intake, 4in dp back exhaust, gear head tunes All deletes done now.
flow pro hot pipe. CCV mode.
2013 dodge charger
scott2001 is offline
post #6 of 27 (permalink) Old 12-27-2010, 03:24 AM
DEMON's Avatar
a seized ujoint will do that. you have to drop the shaft to check for a seized joint though. there won't be any play. but seized caps will give you a weird vibration.
Luke
'06 Ford F450 CC DRW Lariate 24" Alcoas & Toyos
'98 Freightliner FLB C12 13spd 244"
'73 Chevy RS/Z-28
Originally Posted by swamp_ratt View Post
yeah its similar to that one but unfortunately not nearly as long or as cool
DEMON is offline
post #7 of 27 (permalink) Old 01-02-2011, 02:33 AM
IL7.3 Powerstroker's Avatar
Send a message via Yahoo to IL7.3 Powerstroker
center carrier bearing is probably shot
easy replace and reinstall new unit
2002 F-350 Supercab longbed
AFE intake Bully Dog 5" exhaust
Swamps sticks, DP tuned
IL7.3 Powerstroker is offline
post #8 of 27 (permalink) Old 01-05-2011, 12:44 AM Thread Starter
Would either of the above cause a vibration on just the one side?
post #9 of 27 (permalink) Old 01-05-2011, 01:46 AM
DEMON's Avatar
no it wouldn't.
Luke
'73 Chevy RS/Z-28
DEMON is offline
post #10 of 27 (permalink) Old 01-05-2011, 12:55 PM
Aint Got Non
OuchThatHurt's Avatar
I asked a similar question for my truck the other day and this answer makes more sense. Mine vibrates (like a humming) at 60+ mph, but my jitters while taking off. The harder i mash it the harder and more fierce the jitter.
How can you tell if the center ujoint is bad? Mine seems a little loose without the truck being jacked up. Is that normal.
Donnie... 06 F350 Harley leveled ang exhaust. Does the job!
USCG "Sea life is the only life"
OuchThatHurt is offline
Human Verification
