35 12.50 on f250 with leveling kit question. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 18 (permalink) Old 10-24-2010, 02:33 AM Thread Starter
I want to know if 35 12.50 will fit on an 06 f250 with a 2.5 inch leveling kit. They will be on 20-10 rims with 4.5 inches of backspacing. The truck will have a f350 block in the rear also. Will the truck rub at all. My front balance is trimmed and my inner fender is pulled back about an inch as well. Hoping to clear the tires with no rubbing.
TT
Zoodad mod, high idle mod, blue winshield washer fluid, cat delete mod, tinted windows
jonnysteals is offline
post #2 of 18 (permalink) Old 10-24-2010, 02:52 AM
<-MONEY PITT!!
ifitssmokinitsstrokin's Avatar
Re: 35 12.50 on f250 with leveling kit question.
I Think you will be fine. I ran 35s on a leveling kit on my 2006 Didn't rub at all,but I'm not sure on backspacing.
2010 CCSB Afe Intake and dual exhaust
2006 CCLB F-250 Studs,Squeez,EGR delete,RR to AirDog II and a Airraid Intake & Sct Hot tunes *SOLD*
1963 Chevy Nova II 88mm turbo 408 LSX backhalved and tubbed 9.22 @ 145 @ 5000ft BUILT NOT BOUGHT!
02 Cummins ECSB 5 spd,250s,edge comp 64 over a s475.. Work Truck
ifitssmokinitsstrokin is offline
post #3 of 18 (permalink) Old 10-24-2010, 08:12 PM Thread Starter
Can anyone actually confirm running this setup
TT
post #4 of 18 (permalink) Old 10-24-2010, 09:49 PM
bonanno23's Avatar
my 07 f350 had a leveling kit with 20x10 wheels and 35x12.50 toyo muds. they only way the would rub was turning into a step driveway too quick. I didn't do any trimming so I think you'll be fine. I can't say i remember the back spacing but the wheels stuck out of the wheel well a but.
bonanno23 is offline
post #5 of 18 (permalink) Old 10-24-2010, 10:54 PM Thread Starter
Aren't the 350 like an inch higher than the 250s.
TT
post #6 of 18 (permalink) Old 10-25-2010, 03:41 PM
Fasthog.com
Moroney167's Avatar
Send a message via Yahoo to Moroney167
I am doin the same as you right now and with my searches and questions I think the leveling kit to a minimum is needed. Do to rim width and offset yes. With a regulr 20x9 and not a big offset you would be fine with nothing. I to dd the 3.5 blocks int he rear and like a rake to the truck, however front still sits low. Let me know how you did and also WHAT YEAR IS YOUR TRUCK. That would help.
I got my rims and waitin on tires. I hope it fits without leveling kit but I do hate to have rubbing anytime. So 2.5" daystar leveling kit is gonna go in and then perhaps 4" blocks to be sure its not lower in rear.
Jim
'12 F-350 RCLB
Stock - 22K mi.
Moroney167 is offline
post #7 of 18 (permalink) Old 10-29-2010, 02:45 AM
Word
Fasttimez's Avatar
You will be fine with 35x12.50's on your truck. You can put 35's on a stock height F250-F350. The only possible way you could rub would be the back spacing on your rim and if that's all then just run some spacers.
Fasttimez is offline
post #8 of 18 (permalink) Old 10-29-2010, 02:56 AM
Fasthog.com
Moroney167's Avatar
Now. I believe all that but my front end is just to low. I wish I just got a 1.5" spring kit for truck and kept rear stock 350 blocks. But back to backspacing I did 20x10 with -25 offset. What's ur thought on that. I know the average KMC rims an all would be fine but I feel like these for sure are going to be to far out. Even though I only have a smaller 35x12 or so. 285/65-20 BFG. I got sa 2.5" level kit an big blocks comin.
Jim
'12 F-350 RCLB
Stock - 22K mi.
post #9 of 18 (permalink) Old 10-29-2010, 11:45 AM Thread Starter
I dunno I talked to two local kids with a 2.5 inch kit and 35 and both their trucks rub. Think I might just bite the bullet and lower my truck down to a leveling kit.
Trucks an 06
TT
post #10 of 18 (permalink) Old 10-30-2010, 12:40 AM
I FINALLY JUMPED!
desertwheeler's Avatar
I ran 325 65 18's with one inch of front lift, only rubbed on the radius arms. But that was stock wheels.
08 CC SB 4x4
HID's, N-FAB prerunner bar 3 HID's, N-FAB steps
2.5" Icon lift, 35's, 55 gal aero tank, S&B intake
H&S tuned, Nothin special.....
desertwheeler is offline
Human Verification
