10.5 vs Dana 80 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 01-15-2010, 12:08 AM Thread Starter
WWDD
Dzchey21's Avatar
10.5 vs Dana 80
The last couple diesel power challenges have got me thinking...
I keep wondering if I should do a dana80 swap, seems like every year there is someone who spins and axle tube, or snaps a pinion shaft or something on a ford. Hate to have a bullet proof truck other than something like that
couple trucks one fast one not
Dzchey21 is offline
post #2 of 13 (permalink) Old 01-15-2010, 05:10 PM
Busy Busy
Marty's Avatar
Re: Diesel Power Challenge 2010*
You could weld your center section to your axle tubes.
With nitrous you're pretty close to my power range on my previous setup and I have not had a problem yet out of mine.... 200k miles on the drivetrain.
443.553.9234 - 410.392.3262
Elkton, Maryland
2005 F450 - Tow Bitch
Marty is offline
post #3 of 13 (permalink) Old 01-15-2010, 06:57 PM Thread Starter
WWDD
Dzchey21's Avatar
I was planning to weld the tubes, but scott breaking a pinion shaft last yeah got me thinking then he broke one a few weeks later at a sled pull, I plan to drive my truck everywhere next year not ride on a trailer lol
Dzchey21 is offline
post #4 of 13 (permalink) Old 01-15-2010, 07:01 PM
Busy Busy
Marty's Avatar
Well his axle tubes were not welded, his ladderbar setup was bolted to the frame and the C-channel was affixed with Ubolts to the axle tube. He has since upgraded that setup and also went with a Dana 80.
I'm not telling you not to get a dana 80... I'd like to have one as well... but your Sterling should work for what you do with it.
Elkton, Maryland
Marty is offline
post #5 of 13 (permalink) Old 01-16-2010, 02:50 AM
Laces Out
bigrpowr's Avatar
the 10.5 is just fine.
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #6 of 13 (permalink) Old 01-16-2010, 03:47 AM Thread Starter
WWDD
Dzchey21's Avatar
Re: 10.5 vs Dana 80
The Dana 80 was just a thought, I know we dont hear about breakage very often, but my truck is as heavy as it gets with a 10.5 under it, with big tires to boot.
I dont even know what it takes to swap an 80, im assuming its pretty straight forward? Just dont know about the axle width or anything like that. Welding mine is comming soon i know that much, what else is needed to make them strong/stronger?
Dzchey21 is offline
post #7 of 13 (permalink) Old 01-17-2010, 07:55 PM
DieselDANO's Avatar
Re: 10.5 vs Dana 80
I am swapping my rear to an aam 11.5 with a detroit truetrac an 35 spline shafts instead of 31 spline an i use my truck to pull, drag an daily drive
DieselDANO is offline
post #8 of 13 (permalink) Old 01-18-2010, 01:21 PM
Sahrens0202's Avatar
What is wrong with bolting the ladder bar to the frame?Is there a different/better way to attach it?Just curious as I need some and was thinking of making a set and really only want to do it once. Thanks..
Sahrens0202 is offline
post #9 of 13 (permalink) Old 01-19-2010, 05:59 AM
Wears a tinfoil hat
Ten_Bucks's Avatar
Send a message via AIM to Ten_Bucks Send a message via MSN to Ten_Bucks Send a message via Yahoo to Ten_Bucks
Re: 10.5 vs Dana 80
Send a PM to DrSpeed on here for the D80 swap. He has done it to his truck.
Scott
Ten_Bucks is offline
post #10 of 13 (permalink) Old 01-19-2010, 11:35 PM
Busy Busy
Marty's Avatar
Re: 10.5 vs Dana 80
Usually you have a shackle at the front if you have two fixed points on the axle. Scott's were solid mounted and he ripped them right out of the frame. It was pretty catastrophic.
He now uses 4 bolts per frame mount instead of two.
Elkton, Maryland
Marty is offline
Human Verification
