How do you correctly measure your lift - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 04-25-2012, 04:20 AM Thread Starter
Dont know what I want
Jonesin's Avatar
I dont really know how to word this but, how would you determine how much lift you have if you didnt install the kit? Is there a specific way to do this?
Jonesin is offline
post #2 of 19 (permalink) Old 04-25-2012, 05:48 AM
Bigbody250's Avatar
Re: How do you correctly measure your lift
measure the distance from the frame to the axle on your truck and a stock truck. subtract the two and viola... you've got the lift height.
Bigbody250 is offline
post #3 of 19 (permalink) Old 04-25-2012, 09:28 AM
IN that measurement you would have to take in the height of the bigger tires over stock also
nukewelder is offline
post #4 of 19 (permalink) Old 04-25-2012, 05:17 PM
The Butcher's Avatar
The distance he is telling him to measure is between the frame and the axle, so the tire size wouldn't change that measurement.
'05 Excursion Limited, 8" Full Traction Coil-Over Conversion w/King reservoir, 38" Mickey Thompson MTZ, 4.56 gears, ARB front and rear, Sinister Diesel Complete 6.0 solution, PowerMax, AFE intake, MBRP 4", Tunes from Eric at Innovative
2015 Platinum, 8" Icon Stage 4, 38" Toyo M/T, 20x10 Dropstar 645 MB wheels, Carli Long Travel Air Bags.
The Butcher is offline
post #5 of 19 (permalink) Old 04-25-2012, 05:22 PM
chasin beer drinkin women
Wilson444's Avatar
but it wouldnt account for a body lift
95 PSD zf5, straight pipe exhaust, 35" bfg all terrains.
Wilson444 is offline
post #6 of 19 (permalink) Old 04-25-2012, 06:06 PM
True, but if he has a body lift it will be pretty easy to tell (and measure that).
post #7 of 19 (permalink) Old 04-25-2012, 06:16 PM
BigKid's Avatar
I could be wrong, but if I'm not mistaken, they figure your tires in with it. Ex. I had an 8" lift from fabteck on my 02. But the rear block they sent was only 5" or so. Not 8" tall. Same with the front leafs, they weren't 8" taller than stock. With that being said, you should be able to measure your truck in stock form, then measure it WITH the lift AND tires on it, and that's what they call xxx" lift. Meaning, if your truck is 8" taller with all the stuff on it, it's an 8" lift.
Again, I could be way off here, and the boys at Truck Toyz will clear all this up. But from past experience with mine, that is what I think.
2011 Cadi CTS-V
2013 F250 ECLB 6.7 2wd
2013 Platinum, SPE tuned
BigKid is offline
post #8 of 19 (permalink) Old 04-25-2012, 06:45 PM
Administrator
Zmann's Avatar
no they don't figure tires in the advertised lift Height
many lift companies just are full of Chit IMHO Real world gains from company to company seem to vary
DTR's Donation page
RIP DTR Ron
you are missed and will live on through your great video contribution to the DIY community
Zmann is offline
post #9 of 19 (permalink) Old 04-25-2012, 07:13 PM
King Dingaling
TANK'S 250's Avatar
Frame to axle..its the only way....BUT...you may have some spring/leaf sagging...lifts drop over time.
TANK'S 250 is offline
post #10 of 19 (permalink) Old 04-25-2012, 07:53 PM
new2deisel's Avatar
I usually use a tape measure
Just kidding man I couldn't resist. Probably not as funny as I think it is
I measure before and after I installed it. Usually don't put the tires on right away so don't need to put that into account. If you do then minus tire difference. I find most quality lift companies will be pretty close to advertised lift but then you have to consider what other acc. you have on the vehicle that might add extra weight.
new2deisel is offline
Human Verification
