Bleeding Brakes Question - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 30 (permalink) Old 05-23-2011, 04:57 PM Thread Starter
Blackford's Avatar
I had to replace the left rear caliper on my truck this weekend, do I have to bleed the whole system, or just the rear brakes?
2011 F-250 crew
Blackford is offline
post #2 of 30 (permalink) Old 05-23-2011, 04:59 PM
TennesseeHillbilly
whitjo's Avatar
Re: Bleeding Brakes Question
Probably just the one you replaced....but do both sides just to be sure. Front will be OK as is.
Early '99 F250, 4X4, SuperCab, "PowerStroke", Auto,
PMT1 PCM, DP 80 tow
ISSPRO gauges
BDS front leveling kit
4" straight piped
Sinister pre-pump mod w/filter
Dick Cepek DC1 w/ Nitto Terra Grappler 325/65R18,
Annoy A Liberal....... Work Hard and Be Happy!
Please dont call me white or Caucasian. It offends me.
whitjo is offline
post #3 of 30 (permalink) Old 05-23-2011, 05:20 PM
All done now
Arisley's Avatar
Gravity bleed. Open bleed valves. Attach a hose and run it into a container (don't use styrofoam). Remove master cylinder cap, top off fluid. Don't let it run empty. Sit back and enjoy a couple of beers, getting up every couple of minutes to top off master cylinder. Close bleeders, top off fluid, put cap on. Enjoy your effortless bled brakes.
Arisley is offline
post #4 of 30 (permalink) Old 05-23-2011, 05:31 PM Thread Starter
Blackford's Avatar
You don't have to do the usually process of someone pumping the brakes as you loosen and tighten the bleeders?
2011 F-250 crew
post #5 of 30 (permalink) Old 05-23-2011, 05:51 PM
All done now
Arisley's Avatar
I have not used that method in years, not since I found out about gravity bleeding. In fact, the old method will cause foaming issues on modern brake systems.
Arisley is offline
post #6 of 30 (permalink) Old 05-23-2011, 07:10 PM
TennesseeHillbilly
whitjo's Avatar
If you have access to one.....a pressure bleeder will do the job very well.
Only problem is you ain't gonna have time for two beers!
Andy's way works real well too......just don't test drive for a while afterwards.....
PMT1 PCM, DP 80 tow
ISSPRO gauges
4" straight piped
whitjo is offline
post #7 of 30 (permalink) Old 05-23-2011, 07:16 PM
mroutlawoffroad
OUTLAW-OFFROAD's Avatar
Any tips on getting bleeders to break free
96 cclb 10" lift 38" tires.
6 pos custom tuned chip, AD injectors, hoodstack, fpr shim,isspro gauges, electric fans, Built trannismission.
OUTLAW OFFROAD traction bars.
OUTLAW-OFFROAD is offline
post #8 of 30 (permalink) Old 05-23-2011, 08:35 PM
All done now
Arisley's Avatar
Never had one that was that tight.
Arisley is offline
post #9 of 30 (permalink) Old 05-23-2011, 09:54 PM
R.J.'s Avatar
Now that is what I call working smarter not harder I gotta give this method a try
Bob
02, F250, 4x4, CC, Auto, Warn manual hubs, Line-X, Isspro Pyro, Boost, Trans temp and Fuel pressure gauges. Wicked Wheel, AIS intake, John Wood valve body, BrakeSmart, DuraFlap Mud Flaps, 6.0/31 row tranny cooler, ITP Regulated Return Kit, Dieselsite coolant filter & 203 thermostat. Cat ELC coolant, MagnaFlow premium exhaust.
R.J. is offline
post #10 of 30 (permalink) Old 05-23-2011, 10:26 PM
cj45lc's Avatar
It works like a champ
2000 F-250 SCLB 7.3 auto 2wd PHP tunes, w-w, 4" exh tb, 3 guages, zoodad, NCH ccv mod, AIS
cj45lc is offline
Human Verification
