6.7 powerstroke vs camaro - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
post #1 of 26 (permalink) Old 03-25-2017, 04:17 AM Thread Starter
I have 2012 Ford F-250 with custom tunes on a h&s & dpf delete ,CAI & 200 shot of nitrous . I was wondering if ya think I keep up with a 2014 camaro SS with CAI , cat delete , & tune ..
Ibarra2601 is offline
post #2 of 26 (permalink) Old 03-25-2017, 04:37 AM
Trust me, I got this...
Cummins Junkie's Avatar
Garage
Re: 6.7 powerstroke vs camaro
Crew cab? Long bed? Short? I doubt it. The 6.7s are fast (esp. compared to what Im used to), but Im thinking the camaro is faster. But then again, I've been proven wrong before....
Shoulda bought a Cummins. May or may not have a cummins swap in the works.
1997 7.3L XLT, 4x4, 5spd, 307k, TS chip, 6637 filter, 4" straight piped dual exit
If you got a D60 or tan superduty/OBS seats PM me.
Cummins Junkie is offline
post #3 of 26 (permalink) Old 03-25-2017, 04:39 AM Thread Starter
Crew cab . Short bed but true . Tomorrow I race it from a 35 roll
post #4 of 26 (permalink) Old 03-25-2017, 12:16 PM
Master BS'er
jamiesaun's Avatar
Basically, there's no frickin way dude. Sorry, but it's not a fair comparison. Your Truck was not designed to beat a Camaro, it was designed to pull. It's like putting a body builder up against a track runner in a 100m dash. Have a look at this. These are rough numbers and I picked the high end of scale for both vehicles, so each vehicle was handicapped equally. Should be pretty close anyway.
2014 Ford f250: weight- 6,914lbs. horse power-400. (6914/400=17.3lbs per HP.)
2014 Camaro: weight- 4,374lbs. horse power-500 (4374/500=8.8lbs per HP.)
This means that:
Each horse power of your truck needs to accelerate 17.3lbs per second every second
Each horse power of the Camaro needs to accelerate 8.8lbs per second squared.
(Power = torque x rpm / 5252.)
See what you're facing? It's not a fair comparison.
Jamie.
Ps...Im pretty frickin awesome!
"The length of an attack depends upon the arrival of another gun." Greg Gutfeld.
jamiesaun is online now
post #5 of 26 (permalink) Old 03-25-2017, 12:26 PM
Master BS'er
jamiesaun's Avatar
Also, why the hell do people chip their gas engines? Well, I guess I know why, and it will work a little bit, but only a little bit. It will not have nearly the same effect as it will in a diesel, which I am also not a proponent of. If I remember right, the ratio for best power is around 12:1 for gas I think. So that's a pretty small gap and the timing is already pretty far advanced these days. Basically, it seems like a big risk for such a small gain.
Then again, if ya had a small pecker, I guess ya would want it just that much bigger. That must be why people put these stupid cool air intakes and chips in their gas engines.
Jamie.
post #6 of 26 (permalink) Old 03-25-2017, 12:32 PM Thread Starter
He made 425 hp on the dyno & I made 720hp with nitrous
post #7 of 26 (permalink) Old 03-25-2017, 12:43 PM
Moderator
Sbluke55's Avatar
Not going to happen. The weight difference will kill you.
01 f-250, Standard
Sbluke55 is offline
post #8 of 26 (permalink) Old 03-25-2017, 01:16 PM
Master BS'er
jamiesaun's Avatar
Okay, run the numbers through the same equation.
6914/725= 9.5lbs per HP.
4374/425= 10.2lbs per HP.
Now we're talking. It's essentially even, assuming we have the weight right for both vehicles. So now where each engine makes its power is going to be a much bigger factor. Gas burns much faster, has less reciprocating mass, and shorter strokes. Meaning it revs quicker. Will that be enough? In theory it shouldn't matter, as the power to weight is now in you're favor, and more rpm= more total power for both engines equally.
I don't know man. Let us know how it turns out.
Jamie.
post #9 of 26 (permalink) Old 03-25-2017, 01:21 PM
Moderator
Sbluke55's Avatar
His truck should be closer to 7800.
01 f-250, Standard
Sbluke55 is offline
post #10 of 26 (permalink) Old 03-25-2017, 01:26 PM
Master BS'er
jamiesaun's Avatar
7800/725=10.5lbs per HP
It's dead even. Anybody willing to place bets?
Jamie.
Human Verification
