The "Tightwad mod" Fuel Bowl delete and regulated return for peanuts. - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
post #1 of 38 (permalink) Old 05-05-2011, 04:11 AM Thread Starter
I know nothing...
joedaddy's Avatar
1st, this is a mod that will require cutting and grinding on your existing fuel bowl return. If you are not confident in your fabricating ability you might reconsider.
Total cost > $50 <
Start by removing the turbo to plenum tubing, AKA spider. Make sure you stuff it the openings with some rags, some parts are small.
Then drain your fuel bowl, it's the yellow lever at the 7 O'Clock position of the fuel bowl, push to the left. Then use a 1/2" drive and long extension to remove the 13mm bolts in the back of the FB that secure it to the block. I busted 2 good 3/8" ratchets learning this.
Once you've unbolted the FB take the braided (return) lines loose from the regulator and return line (hose) at the back. Then unbolt the reg from the bowl. Remove the top left worm clamp and hose from the fuel pump, the loosened FB should give you plenty of access. Then the lowest clamp and hose. If these 2 hose wont come don't worry they will tear off anyway once you pull th FB.
With the FB gone you can now see the fuel pump. If you are not familier with it the top left port the low pressure to the filter, the top right is inlet feed from the tanks, the bottom is inlet feed from the filter. the out the back to the back of the heads, through the heads out the front into the braided return lines you previously disconnected, and into the regulated return.
Now the factory RR, take time again to understand what is going on here. The backside is the inlet feed from the FB, when you removed this you probably noticed a nasty screen, behind that there is a plastic tube restrictor and behind that a plastic ball, these can be tossed in the trash. The fuel goes through there to the left and into the cup looking thing where it mixes with return fuel the out the nipple in back, or you may have a different model that has no cup but a lid with a nipple out the bottom. The left side is the regulated return, the large brass colored bolt is the Fuel Pressure Regulater lid, behind it you will find a spring and aluminum needle that does the regulating.
With the lid/cup removed you can see the inner chamber, the hole in the center is where reg meets ret, this is where you tap a 3/8 ntp nipple to become the new fuel return. On the cupless model you'll need to pre-drill the hole 1st with a size or 2 smaller bit than the tap.
To the right of the feed that goes down into the chamber is where you'll start cutting, spend some time making sure you fully understand this step, after the 1st cut you're all in! REMEMBER YOUR SAFTEY GLASSES AND GLOVES!!!!!
Here's what you're after, this will take many cuts and some staring to get right. You can see that I've already tapped the center and placed the new return nipple as a guide.
And the finished product. You'll want to disassemble and clean vigorously before re-assembly. This is also a good time for the FPR mod which is just a BB in the needle uder the spring.
Re-assembly is pretty self explanitory once you've come this far, the braided lines go bac where they were and the new return plugs right into where the old 1 did.
So far I haven't needed to clamp the device in place, it's so light the return hard line sorta suspends it in the valley.
Then it's your choice of filtration, I went with a 10 micron transfer tank assembly, it has a see-through sediment bowl and water drain at the bottom, it was about $30 at the tractor supply store, the fittings to go from 1" to 3/8" nipple were another $5-10 and I made the hanger out of a piece of flat stock 1"x 1/8" and used 1 1/4 U bolts to mount.
All but the fittings and reg spring/needle can be tossed.
GOOD LUCK with yours!!!!
Joel.kist likes this.
Doesn't roll with anyone or tag along to be cool...
joedaddy is offline
post #2 of 38 (permalink) Old 05-05-2011, 04:18 AM
KEM Sales & Support
Re: The "Tightwad mod" Fuel Bowl delete and regulated return for peanuts.
subscribed...
KEM Racing
KEM Performance
patrickke is offline
post #3 of 38 (permalink) Old 05-05-2011, 04:21 AM
psdguy97
psdguy08's Avatar
What are the benefits of this?
95 F-250 ECLB
6637 air intake, 3 inch dp to 4 inch exhaust, EBPV delete, ccv mod, glowshift gauges ( fuel pressure, boost, trans temp, pyrometer ) Dp tuner ( no start, stock, 80hp econo, 60hp tow)
Cobra 29 classic w/nightwatch, Wilson 1000 magnet mount, weather guard backrack, code 3 lightbar.
psdguy08 is offline
post #4 of 38 (permalink) Old 05-05-2011, 04:23 AM
Built not Bought
1990 Scorpion's Avatar
No leaky fuel bowl that causes a big mess and cleans the valley up.
1996 7.3L Powerstroke
T6 Chip with Tony Wildman Tunes
Autometer Cobalt Gauges
3 inch DP, 5 inch Straight Pipe
S&B Intake
Billet Torque Converter, Triple Kevlar Clutches, Transgo Shift Kit.
1990 Scorpion is offline
post #5 of 38 (permalink) Old 05-05-2011, 04:26 AM
psdguy97
psdguy08's Avatar
Hm. might try this when i replace my hpop
95 F-250 ECLB
psdguy08 is offline
post #6 of 38 (permalink) Old 05-05-2011, 04:33 AM
swamp_ratt's Avatar
good write up! STICKY!!
1995 F350 CCLB DT360/Allison
1997 F350 RCLB 460/E40D
2001 Jetta TDI 5spd (51mpg work beater)
1995 F350 CCLB 2.5 tons/57s Front, 53s Rear
swamp_ratt is offline
post #7 of 38 (permalink) Old 05-05-2011, 11:05 AM Thread Starter
I know nothing...
joedaddy's Avatar
That's reason enough right there. The factory FB is smack in the way of the HPOP and IPR. The IPR is out and back in now in about 10 minutes.
joedaddy is offline
post #8 of 38 (permalink) Old 05-05-2011, 11:19 AM
bluedge8's Avatar
interesting, I have a spare laying around I'll have to look into this. Also Joe, did I remember right that you don't want to use galvanized fittings (left side of fuel filter, 2 elbows), because is can de-laminate when in contact with diesel??? I could be totally wrong but that's what I remember.
1997 f250 4x4 sclb, auto, 3.55's, 191k, diy intake w 6637, ccv mod, pyro, boost, trans gauges, 3" dp to 4" single exh. super chips for now. scangauge
Originally Posted by jdc753 View Post
Besides there is absolutely no way to idiot proof something, since they are always coming out with better idiots by the day
bluedge8 is offline
post #9 of 38 (permalink) Old 05-05-2011, 11:23 AM Thread Starter
I know nothing...
joedaddy's Avatar
That sounds right, these are cheapy's, they only had rust on the inside. I took a wire pipe brush to them.
joedaddy is offline
post #10 of 38 (permalink) Old 05-05-2011, 11:24 AM
psdguy97
psdguy08's Avatar
I wish I knew abou this a month ago when I replaced my fuel bowl and pump
Does anyone know how much a new fpr costs if I **** up the one on the truck? Also where do the fuel lines that go to and from the new filter go?
95 F-250 ECLB
psdguy08 is offline
Human Verification
  LinkBacks (?)
LinkBack to this Thread: http://www.powerstrokenation.com/forums/87-%5B1994-1997-aftermarket-performance%5D/102394-tightwad-mod-fuel-bowl-delete-regulated-return-peanuts.html
Posted By For Type Date
1997-powerstroke-fuel-system This thread Refback 02-22-2016 07:33 PM
OBS 7.3L air bubbles in fuel system - Pirate4x4.Com : 4x4 and Off-Road Forum This thread Pingback 01-05-2016 02:36 AM
"Tightwad Mod" Done This thread Refback 12-28-2015 08:33 PM
My E-Fuel Conversion - Ford Powerstroke Diesel Forum This thread Refback 11-28-2015 04:12 PM
what electric SD fuel parts needed for OBS? - Page 2 - Ford Truck Enthusiasts Forums This thread Refback 11-08-2015 05:31 AM
The "Tightwad mod" Fuel Bowl delete - Ford Truck Enthusiasts Forums This thread Refback 10-30-2015 01:48 AM
You may not post new threads
You may not post replies
