Factory ford navigation lock out - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 12-15-2009, 04:53 PM Thread Starter
VMAX's Avatar
Has anyone heard of a way to over ride the navigation so you can enter addresses on the fly? I am so use to my old kenwood nav system entering info on the fly. This will suck having to pull over every time I want to change something. I am a contractor and use nav all the time. Thanks in advance.
VMAX is offline
post #2 of 10 (permalink) Old 12-16-2009, 12:48 AM
Never growing up
Re: Factory ford navigation lock out
The lockpick is supposed to work for these, but its not cheap -http://www.coastaletech.com/synclockpick.htm
2009 F-350 DRW King Ranch Crewcab, 4X4, auto, SBI Intake, JAD Solutions LED marker lights, Recon tails, side and cab lights, MBRP cool duals.
2006 Mercedes E320 Bluetec
Go Navy! USN-Retired
radio flyer is offline
post #3 of 10 (permalink) Old 12-16-2009, 01:08 AM
it's an 02 05 08
turbodiesel_02's Avatar
rumor has it that some how you can unlock it with ford's computer,but im not sure it just what i have heard
2002 ext. cab lwb 4x4 7.3
05 front 08 rear conversion
4in lift,forged rod motor,tunes by tsd,bts trans,6.0 transcooler,6 autometers to watch,studs,springs,push rods,238cc hybrids,itp reg return,stealth hpop,tsd custom fuel system and sump,an so on
6.0's pay the bills and 6.4's soon..
turbodiesel_02 is offline
post #4 of 10 (permalink) Old 12-16-2009, 02:03 AM
jdgleason's Avatar
Ive heard you can cut the cable that tells it the truck is in park, but the nav tells it your moving anyway...
'09 F350
-JD
jdgleason is offline
post #5 of 10 (permalink) Old 01-06-2010, 05:55 PM
Got this off another forum. Thanks to wiingnut
My nav now allows me to access POI's while the vehicle is in motion. You will not find this on internet. I finally found out at work.
Here we go!
1. Take vehicle outside and agree to nav instructions. The gps needs to know its position.
2. Push hard nav button (on right side of radio). Go to your address book. Pick any of one of your saved addresses. Now that address is highlighted, look to right and push soft edit button. You will now see name of saved address.
3. Clear name of saved address and type in F-DEVELOP ON
(make sure to put space between DEVELOP and ON).
4. Now look to the upper left corner and you will see the word ADDRESS. Place your finger directly under the A and hold. If you do this right, the screen should change to the map screen.
5. Now push your hard menu button (on left side of radio). Across top of radio push soft SECURITY button. You have now entered security screen. You will see nothing in the lower right most corner of nav screen. Push your finger and hold in that position till the screen changes.
6. You now have entered a parameter screen. Locate DRIVING RESTRICTIONS release. When you push the button it should change to driving restrictions stop. Exit the screen by pushing the soft BACK button.
7. Congrats you have just programmed your factory nav radio. NOTE: Every time you turn your vehicle off, you will need to repeat steps 5 & 6.
Good luck and enjoy. If you choose to monkey around with your other parameters, do so at your own risk. I will not be responsible for your dealer service call. If you have any further questions, please pm me and I will do my best to help. This programming sequence should work for only the so called first generation navs. It will not work in the MY09, second generation. This has been used to reprogram many MY 07 and MY 08 Ford vehicles.
FrancesFord is offline
post #6 of 10 (permalink) Old 01-06-2010, 09:44 PM
You can also do step 5 & 6 while underway, if you don't want to re-set it each time you start up.
post #7 of 10 (permalink) Old 01-07-2010, 01:26 AM Thread Starter
VMAX's Avatar
found this online also. dont really want to do steps 5 and 6 each time but if that is what it takes then so be it I guess. Thanks
1978 Dodge Little Red Cummins Express Drag Truck.
2008 F250 Powerstroke 6.4, S&B, Spartan, 5" exhaust
Thanks to SouthernSportzRacing, HighTechTurbo and HotRodDiesels
VMAX is offline
post #8 of 10 (permalink) Old 01-07-2010, 01:37 AM
It takes 5 seconds.....tops....to do steps 5 and 6. And as mentioned you can do it while underway.
post #9 of 10 (permalink) Old 01-07-2010, 02:28 PM
X2 with FrancesFord, I did this and other then steps 5/6 your good to go.
cbenn is offline
post #10 of 10 (permalink) Old 01-07-2010, 02:51 PM
PSN Mega Miler
crowz's Avatar
Im going to copy this one over to the library. Someones bound to need this
2002 F250 SuperDuty Lariat PSD 7.3 Crew Cab 4x4 302,000+ miles.
, Valvoline Extreme Blue 5w40 Synthetic,
, Clifford Matrix 50.5x Alarm
, P3 Brake Controller, Swamps Injectors, PHP Tunes
crowz is offline
Closed Thread
Human Verification
You may not post new threads
You may not post replies
