Draining the fuel water separator - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 33 (permalink) Old 12-02-2010, 09:53 PM Thread Starter
When I drain my fuel water separator it just drops about a drop a second with absolutely no water in it.
I have read about people saying you may have to remove it and clean it that crud may build up inside.
How does everyone elses drain? Does it stream out? Is it ever a noticeable amount of water?
Ford just replaced the filters about 5,000 miles ago.
Now my light is coming on and I am starting to wonder if it's the sensor or if it's trapped in there.
Thanks for the help.
(SOLD) 2008 F250 H&S Mini w/ Bully dog mount, Flo-Pro DPF/CAT delete, AFE stage 2, Viper 5901 Remote start.
Grunn is offline
post #2 of 33 (permalink) Old 12-02-2010, 09:56 PM
StackinChipsLikePringles
WoodBoy's Avatar
Send a message via Skype™ to WoodBoy
Re: Draining the fuel water separator
It seems that we cant get a definite answer as in how the water seperator is supposed to drain.. Mine always drained by dripping slowly maybe 6 drips ever 30-45 sec. along with others, then others say theirs streams out and doesnt stop till they turn it off, etc
2010 F250.. Stock looking
What is right is not always popular, and what is popular is not always right.
WoodBoy is offline
post #3 of 33 (permalink) Old 12-02-2010, 10:22 PM
Newbie
tbsimmons's Avatar
Last time I drained mine it was a stream till I shut the valve.
Thanks for asking, need to go drain it again. Been a few weeks.
2008 F450 4x4
Stock
tbsimmons is offline
post #4 of 33 (permalink) Old 12-02-2010, 10:47 PM Thread Starter
I ask because my light keeps coming on and I get zero water out of it.
I hate to bring it to the dealership for just this.
Grunn is offline
post #5 of 33 (permalink) Old 12-02-2010, 11:47 PM
austin229's Avatar
Most likely its gunked up in there. You can try turning the key on with the valve open to force what is blocking it out. I took the pump off my brother in laws truck to clean it. His WIF light was on and it would not drain. It was ridiculous how much crap was built up in there.
2012 F250 Lariat
37x13.50x20 Toyo's
2.5" Icon
Helo 20"s
austin229 is offline
post #6 of 33 (permalink) Old 12-02-2010, 11:52 PM Thread Starter
How many miles were on it? I'm only at 20k but it is 2 1/2 years old.
Grunn is offline
post #7 of 33 (permalink) Old 12-02-2010, 11:57 PM
austin229's Avatar
Near 40k I think. Ford wanted to charge him for a new pump because the sensor was bad. A good cleaning, a new 30 dollar gasket, and 30 dollar sensor and he was back going. If you are going to take the cover off to clean it I would suggest to go ahead and buy the gasket that goes behind it, Its not that much and would save some time if yours has stretched.
2012 F250 Lariat
37x13.50x20 Toyo's
2.5" Icon
Helo 20"s
post #8 of 33 (permalink) Old 12-02-2010, 11:57 PM
Diesel fanatic
GMAN1's Avatar
I get about 16 OZs every time I drain mine. It stops draining after about 1 minute.
2009 F250 Lariat cc/sb sterling gray - Just a couple of bolt on mods.
GMAN1 is offline
post #9 of 33 (permalink) Old 12-03-2010, 12:29 AM
Mine has the lever broken off. Can you buy just the cover with the lever? Just bought the truck and the light came on, crawled under and lever is not there.
FFR3247R is offline
post #10 of 33 (permalink) Old 12-03-2010, 05:12 PM
zabeard's Avatar
Mine usually drains a pretty good stream too.
2003 Ford Ranger on 42s, COs, Caged, Fully built 5.4L DOHC, blah blah
1997 F350 CCLB 4WD Auto. Basics 4" Exhaust and 6637 filter.
zabeard is offline
Human Verification
