coolant leak driver side 2008 6.4 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 02-07-2012, 09:57 PM Thread Starter
on the radiator driver side it is coming down the shroud . when i look up there is white stains under the top hose but not directly under it is 6 inches down. i just changed the oil 2 days ago then cleaned under the hood w degreaser so the white residue may be from that. it leaks directly onto the bar then to the ground . the coolant level is not low yet. i have 60k miles on it and called the dealer to see if it had been replaced or was covered under powertrain warranty. they said no. could the top hose leak and not hit till 6 inches down then only go behind the shroud ? is this a common problem? i looked on ebay and noticed that the radiator is 600 up so i hope it not to common as i wanted to put 300k plus on it
doublesrtroker is offline
post #2 of 19 (permalink) Old 02-07-2012, 11:44 PM
Jeff @ Spartan's Avatar
Re: coolant leak driver side 2008 6.4
The radiator itself, lower radiator hose, and upper radiator hose are all prone to leaking/failing on these trucks. It is very common.
Jeff Dodd
2012 Ford F-250 CC/SB
Jeff @ Spartan is offline
post #3 of 19 (permalink) Old 02-08-2012, 02:57 AM
I had the same sort of problem, I got 69000 miles. It was my radiator, it was covered under warranty, but I had complained before about a leak that they couldn't find, so maybe that's why they covered it..
2008 job2, h&s mini, studs, egr delete,cai, 4 in cold side, 4 in down pipe, 5 in back.
bigdaddy67 is offline
post #4 of 19 (permalink) Old 02-15-2012, 02:57 AM
jmkeck's Avatar
Garage
Mine was not covered after 36000 miles, cost me $1,200
2015 F250 Lariott
jmkeck is offline
post #5 of 19 (permalink) Old 02-15-2012, 03:33 AM
jsrickert2's Avatar
Radiator hose, i had to replace mine it was $88 for the hose.
jsrickert2 is offline
post #6 of 19 (permalink) Old 02-15-2012, 04:08 AM
clayton's Avatar
My bottom hose leaked at the connection(orings), they replaced it under warranty.
clayton is offline
post #7 of 19 (permalink) Old 02-15-2012, 08:31 PM
powerstroker67's Avatar
The new upper and lower hoses have double orings for a better seal. First Ford found the uppers leaking at the t-stat housing, then they found the lowers leaking at the split between the two halfs of the lower hose center bottom of truck.
2011 F350 Lariat,CC/SB SPARTAN Beta tuning,AFE intake,Magnaflow 5" exhaust, Powerstroker67 CAT/DPF 5" delete, 8" Procomp, American Force 22", 37" Dunlop
Authorized Spartan,H+S,SCT dealer. Leading the way in custom built CAT/DPF Downpipes
powerstroker67 is offline
post #8 of 19 (permalink) Old 02-16-2012, 03:56 AM
C10H20
Dirty Curry Racing's Avatar
Anyone know of any 6.4's running a custom radiator after the stock unit fails?
Rig: 2010 F250 CC SB 4x4
Tuner: H&S Mini Maxx HD300
Tuner setting: Hot
Trans Tuning: 1 shift Schedule low modifier
Curb Weight w/Driver: 8360lbs
Best 1/4 time: 13.55 @99mph with HD300 tune
Dirty Curry Racing is offline
post #9 of 19 (permalink) Old 02-17-2012, 04:59 AM
yes, and they have a lifetime warranty. i would go with those b4 going back to ford.
http://www.dieselpowerproducts.com/p...roke-2508.aspx
can be expensive but they have exceptional quality
joe_r_dog is offline
post #10 of 19 (permalink) Old 02-17-2012, 02:03 PM
NObama
03sixspeed's Avatar
mine was leaking at the lower connection to the water pump, when it leaks it drips onto track bar then to ground if it leaks bad enough... maybe check there? I just had to replace the o-ring but its a PITA to get to it there.
2010 F-250 CCLB FX-4... Spartan,custom 5" DP back,PS67 DP,Homemade intake,CAC tube,EGR delete,CCV reroute,2.5" Newton,20x10 Revolvers,Timbrens
Originally Posted by Hanging_Heels View Post
Welcome to United States of Obama. Ran by buncha tree hugging, socialist, liberal, hippy, vaginas...
03sixspeed is offline
Human Verification
