6.4 swap - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 24 (permalink) Old 06-26-2011, 01:50 AM Thread Starter
TimmyaleX
Question 6.4 swap
Anyone ever swap a 6.4 to a super duty that came with a 6.0? Possible?
Support Blue Collar Workers
-2008 F-350 XLCCLBSRWZF6
-Fast Idle Switch
-5" DP back
-Innovative livewire
-No Limit
-Newton Fat Boy Traction Bars
-Ebay Leveling Kit
-ICON adj. Trac BAr
-NITTO Terra Grapplers
-Flo Pro EGR delete
-South Bend 3250
-Spartan
-Lab Pit "Stella"
HD-tech-NH is offline
post #2 of 24 (permalink) Old 06-26-2011, 02:03 AM
loud and long
06 stroker's Avatar
Re: 6.4 swap
Anything is possible. Its all depends on how much moola u gots!
06 f250 w/ sct tunes from Gearhead
2"leveling kit w/ 350 blocks in rear
5 inch straight pipe
s&b intake
arp head studs
full egr delete
oil bypass
155/75 injectors
64/71 non vgt
Just bought-97 f250 ext cab long bed
Looking for Dana 60 front axel
RIP MAXINE
06 stroker is offline
post #3 of 24 (permalink) Old 06-26-2011, 01:51 PM Thread Starter
TimmyaleX
Re: 6.4 swap
anyone here ever do this?
-Fast Idle Switch
-5" DP back
-No Limit
-Ebay Leveling Kit
-ICON adj. Trac BAr
-Flo Pro EGR delete
-South Bend 3250
-Spartan
-Lab Pit "Stella"
post #4 of 24 (permalink) Old 06-26-2011, 02:01 PM
WHAT DID YOU JUST SAY?
forcefed6.4ford's Avatar
Re: 6.4 swap
Not that Ive heard of. Should be possible. Depends on the size of your wallet.
forcefed6.4ford is offline
post #5 of 24 (permalink) Old 06-26-2011, 02:21 PM
Re: 6.4 swap
It's possible .........just depends on how much money you got, how confident you are in taking on a project and if you find a donor truck.
Either way it would prolly be cheaper to just mod the 6.0, but then again you may come out ahead if you do the swap and are able to sell a bunch of the parts ya dont need.
02 f250
countryboyrob is offline
post #6 of 24 (permalink) Old 06-26-2011, 05:32 PM Thread Starter
TimmyaleX
Re: 6.4 swap
What would be so expensive about it? The purchase on the motor? what else would you really need? They both use the 5R110? will the 6.0 PCM work? Anyone have info on specifics?
-Fast Idle Switch
-5" DP back
-No Limit
-Ebay Leveling Kit
-ICON adj. Trac BAr
-Flo Pro EGR delete
-South Bend 3250
-Spartan
-Lab Pit "Stella"
post #7 of 24 (permalink) Old 06-26-2011, 08:06 PM
uga33's Avatar
Re: 6.4 swap
Need room for all those radiators.
2012 F-350 CC/SB 4x4 King Ranch*Spartan Tuning*5" Flo-Pro*
uga33 is offline
post #8 of 24 (permalink) Old 06-27-2011, 03:01 AM
Silver Death
GROSSpolluter's Avatar
Re: 6.4 swap
just go buy a 08-10 truck and be done with it. save yourself the headache
North Orange County Blue Oval Crips Chapter
2010 6.4 F250 Ingot Silver
572hp/1078tq
CTS Insight, Airaid Intake, 5.4 coils, ccv mod, snorkle gutted, MBRP cac pipe, H&S xrtpro 300tune, 5" Diamondeye t/b, airdog2, egr delete, Batmo, elite studs
GROSSpolluter is offline
post #9 of 24 (permalink) Old 06-27-2011, 09:40 AM
brooksfruge's Avatar
Re: 6.4 swap
2008 Single turbo 6.4L
-Brooks-
brooksfruge is offline
post #10 of 24 (permalink) Old 06-27-2011, 10:44 AM
Re: 6.4 swap
You need the entire chassis harness, fuel tank sending unit, fuel pump, cooling, engine, transmission (the bellhousing bolt pattern is different), engine harness, pcm, fuel lines, dash harness, gauge cluster, heater box, and pretty much everything else specific to the newer trucks. Best bet is to get a wrecked parts truck, but the good news is it's all bolt in. No fabrication required, other than making room for all the extra cooling on the 6.4 vs the 6.0.
ddillenger is offline
Human Verification
