Blending Toluol (Toluene) with Vegetable Oil to Make VO Blend Diesel Fuel - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 8 (permalink) Old 05-02-2011, 05:48 PM Thread Starter
Banned
Making vegetable oil blend Diesel Fuel (VOBDF) by blending Toluol with WVO
The point of this experiment and video is simply to demonstrating that Toluol will dissolve readily into WVO. It is purely of academic interest and is in no way an attempt to encourage its use or recommend its use over petroleum distillates. I am just posting these experimental blending videos to show that there is a range of solvents that could be blended with waste oils to make diesel fuel. It is up to the user to decide whether they wish to further the experiment by running it on an engine. If you do, then please post your findings on this thread.
The point is making diesel fuel out of waste oils is a form of recycling. And, there are many people making viable and sustainable diesel fuels by blending various solvents with various waste oils. Therefore, there is no reason why the solvents used to thin waste oil need not also be recycled, therefore it is conceivable that someone may come across some recycled Toluol and consider using it as a solvent for making diesel fuel by blending it with waste oils.
Jeffrey S Brooks is offline
post #2 of 8 (permalink) Old 05-03-2011, 12:25 PM
Re: Blending Toluol (Toluene) with Vegetable Oil to Make VO Blend Diesel Fuel
Toluene has a density of 0.862Kg / liter compared to Diesel at 0.832 kg / liter
No matter how much Toluene you use, you will never get the density of a Toluene / Oil blend close to that of Diesel.
Gasoline is better at only 0.737 kg / liter so less would be required to lower the density of the blend.
Now the bad news
The auto-ignition temperature of Diesel is quite low at 210c, Gasoline is 280c but with Toluene it is 550c
Toluene makes a great octane booster with Gasoline because of the high auto-ignition temperature at slow flame propagation.
It is a step in the opposite direction to what you are trying to achieve
kerrynzl is offline
post #3 of 8 (permalink) Old 05-03-2011, 12:53 PM
<----Nice headlights!!!
TylerDurden's Avatar
Yes as kerrynzl said. Toluene, Benzene,acetone,etc. are all found in crude oil and they can exist in differing amounts after refining(distilling). People think they can take A, being oil of whatever origin and mix it with B, solvent of whatever origin and make diesel fuel. It MAY burn in a diesel engine but its just a solution of flammable crap. Not diesel fuel.
Gas and diesel are opposites...gasoline function depends on octane and diesels rely on the right cetane numbers.
This is a fairly dangerous hobby to mix solvents and oils. Recycling, as it was stated, or re-using petroleum based solvents that were used in an industrious way is not only dangerous(you dont know what is in them now after use) but could be illegal. Tread very carefully.
2000 F250 4x4 cc/sb. 6" w/37's and some other stuff.
TylerDurden is offline
post #4 of 8 (permalink) Old 05-06-2011, 05:08 AM
Crazy W85 guy
Send a message via Yahoo to rsr911
Side note: Pertaining to WMO rather than WVO, toluene does not have the dewatering and cleaning effect that RUG has on WMO. I did a test side by side and there was almost zero water separation as opposed to RUG which causes the water and some sludge to fall out.
Recycled/reclaimed solvents are common and most are rather contaminate free. Large solvent users such as adhesive coaters often have solvent recovery systems on their ovens. While basically distilled it cannot be sold as new fresh solvent.
The biggest strike against using toluene however is that it functions as an octane improver. That said when starting with dry WMO I have found it works about the same as RUG as far as solvent thinning goes.
Of course the final blend is not diesel, that does not mean however that the engine won't run as well or better on the blend. I have personally recorded a MPG improvement running W85 which makes sense given the fact that the per volume energy content is higher. In theory (I have not tested on a dyno) the power output of W85 should be 5-10 percent higher for the same reason.
1986 F350 CCLB 7.3 Banks Turbo, 5" stack, currently undergoing a 4x4 dually conversion as well as aftermarket flatbed with goose neck hitch.
rsr911 is offline
post #5 of 8 (permalink) Old 05-06-2011, 05:10 AM
Crazy W85 guy
Jeffery, I'd love to see a test involving naptha!
rsr911 is offline
post #6 of 8 (permalink) Old 05-06-2011, 01:54 PM Thread Starter
Banned
Thanks for posting your most interesting comments Chris. I will plan making a video of blending naptha with WVO. I have a few more solvents that I want to experiment with as well. I will be posting a new video this Monday
post #7 of 8 (permalink) Old 05-29-2012, 06:01 PM
Hello All,
It is not the density which matters actually, rather the viscosity of the mixture. I have been experimenting toluene/diesel mixture in my 1.8 diesel engine for like a year. I have used just randomly %10 of toluene and %90 veggi oil, and engine runs smoothly, only there is always the bad smell of exhaust gas as you know. I am thinking a soln to this also: I plan to put granular activated carbon into the exhaust pipe to adsorp the bad smell.
Anyway, Today I decided to calculate how much toluene is really needed to achieve diesel fuel viscosity, since I am a chemical engineer, a lazy one but I had the time :) and while I was searching on the net I saw your forum, and wanted to share:
Viscosity of veggi oil: 35 cS (average)
Viscosity of toluene: 0.55 cS
Viscosity of Diesel Fuel: 5 cS (average)
Using the formula with VBI index in excel sheet with seek target function, theoretically 71% veggi oil and 29% of toluene mixture gives a liquid with the viscosity of 5 cS and density of 0.8957 kg/liter. This mixture is even better than regular diesel when you think of veggi oils' good lubricating properties :)
Now the bad news
emre is offline
post #8 of 8 (permalink) Old 05-30-2012, 02:06 PM Thread Starter
Banned
Thanks, emre, for posting your comments on Blending Toluol (Toluene) with Vegetable Oil. There is a report of big rigs in Australia that were dishonestly fueled with a blend of WMO and Toluene. Apparently the Toluene melted through the fuel lines of some of the big-rigs and caused several truck fires. So, if one were going to experiment with Toluene as a blending agent above 5% of the blend, then one would want to make sure one had Viton fuel lines.
Like RSR911 said, some people have access to waste forms of Toluene, so why not use free waste solvent to blend with free waste oil to make free fuel? That after all is the point of this series of videos.
Do keep us posted of the results of your experiments.
Human Verification
