EGT sensor problem - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 23 (permalink) Old 03-22-2011, 07:08 PM Thread Starter
Strokin4life's Avatar
EGT sensor problem
My 08 6.4 with 53k miles has a bad egt sensor giving me the "pullover safely now" screen and my dealer wants $357 to replace it. Is this not under the 100k diesel warranty and also if it isn't how hard is it to replace and where exactly is it.
Thanks,
SOLD! 2006 F250 Superduty 6.0L FX4
8" Rough country lift, 2.5" AS Leveling kit
38x13.50R24 Nitto Trail Grapplers
24x12 XD Rockstars
8" Black Stack
2009 F250 FX4 CC Black 6.4- Mods soon to come
Strokin4life is offline
post #2 of 23 (permalink) Old 03-22-2011, 08:59 PM
Wizzard of Odds's Avatar
Re: EGT sensor problem
Thanks,
It should be under the 100k warranty, however..........
The dealer price sounds high, especially if this is one of the sensors in the exhaust. I know those can be had for $40 or so online, and really aren't hard to put in.
EXACTLY what code(s) are you throwing?
2008 F250 FX4, 6.4, Job 2 ~~~ SOLD
Wizzard of Odds is offline
post #3 of 23 (permalink) Old 03-22-2011, 10:06 PM
:whs if its one on the pipe its very easy to replace and not $300
2011 F-150 FX 4 Luxtury package, Eco boost on order
2008 F-350 Lariet, auto, spartanized, 175,000 km
Egr cooler delete built by me
Hg's done cab on by me
2006 yamaha Vmax
2003- F-350 XLT, auto, mostly stock 225,000 km Sold
2003 Suzuki GSKR 1000
1978 F-150 needs a paint job
budtoh3zo is offline
post #4 of 23 (permalink) Old 03-22-2011, 10:36 PM
BFT
IM OUT!!!
BFT's Avatar
should take about an hour
take the passenger side inner fender well out
spray the sensor with some W-D40 it will pretty damn snug, so having it hot from running is a plus
disconnect it from the top. its a plug toward the back of the passenger side valve cover.
hit up 25% discount on ford parts to members - PowerStrokeNation they are a vendor here and will give you a better price on the sensor then you would at the dealer you would go to
he's got a forehead like a drive-in movie theater
BFT is offline
post #5 of 23 (permalink) Old 03-22-2011, 10:38 PM Thread Starter
Aparently there are two sensors, part numbers 12B591 which is under the warranty and 5J213 which isn't. Mine happened to be the one which wasn't. I already paid it and left because i need my truck but i wish i knew where it was and i would have changed it.
24x12 XD Rockstars
8" Black Stack
post #6 of 23 (permalink) Old 03-22-2011, 11:13 PM Thread Starter
Does in know where i can see a diagram of the DPF so i know where the sensor is at? Also where can i see exactly what is covered under the 100K warranty, is there a website that shows this?
thanks
24x12 XD Rockstars
8" Black Stack
post #7 of 23 (permalink) Old 03-22-2011, 11:23 PM
I can get you a pic of the 3 easy to change sensors, the one BFT is talking about i might be able to get you a pic of that one when i get my head off. might be awhile till i get to that. I will go dig my head out of my stock pile and be back in a few.
2006 yamaha Vmax
post #8 of 23 (permalink) Old 03-23-2011, 12:04 AM
The first pic is the front of the DPF system
2006 yamaha Vmax
post #9 of 23 (permalink) Old 03-23-2011, 01:28 AM Thread Starter
Thanks bud. Is that the one i had replaced or is the one thats behind the passenger side fender well the one.
24x12 XD Rockstars
8" Black Stack
post #10 of 23 (permalink) Old 03-23-2011, 01:37 AM
Marc's Avatar
Both EGRT sensors and all three EGT sensors are covered under the 5/100k warranty. Sounds to me like your dealer is jerking you around.
Regardless, if you decide to change it yourself, one thing i would like to add is soak whatever one your replacing overnight with PB blaster. This helps with the ones that want to pull the threads of the "bung" out when you go to unscrew them.
Also, cut the old sensor off right at the top and use a 6 point socket on it. They tend to be tight to break free and an open end wrench will round them off. Another trick on the three in the exhaust can be to use a line wrench, but then put vice grips on the line wrench after it is on the sensor to keep it from opening up and rounding it off. You cant do this very easily on the EGRT1 sensor in the passanger side up pipe though.
You can do the EGRT1 sensor without pulling the inner fender well, but it is kind of a pain.
NHRDA Region 2 Race Director
Marc is offline
Human Verification
