6.4 Block Heater - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 21 (permalink) Old 12-09-2010, 11:20 PM Thread Starter
Edward Scissorhand WanaB
Bushwakd's Avatar
6.4 Block Heater
Does the 6.4 motor have a block heater? If so where is the plug located?
A guy I know has a F550 dump truck and we were talking about block heaters and he says he does not know where the plug is located on the 6.4.
"Real Trucks Don't Have Sparkplugs"
2000 F-250 Lariat, CC, 4x4, LWB,
A few mods to make it better than stock.
250cc hybrids, Stealth stage II HPOP, H-11 Headstuds, Strickly Diesel Reg. Return Fuel, Spearco 6.0 IC, Garrett 38r 1.15 hsg, BTS transmission, Gearhead Tuning
"The Smoke Don't Mean Its Broke"
Bushwakd is offline
post #2 of 21 (permalink) Old 12-09-2010, 11:30 PM
stevestroke08's Avatar
Re: 6.4 Block Heater
Yes , all 6.4's have a block heater , but it won't have the cord if it was not sold in one of the cold weather states or ordered with a cord. The cord should be behind the passenger side front bumper if it has one and if not you can order on and put it on yourself.
2000 Ford F350 DRW CCLB 4x4 Auto
Riffraff- FRx,HPx,Plenum Inserts,AIH Delete Plug
4" Turbo Back Exhaust , Delo ELC
Trans temp and Pyro a pillar gauges B&W Turnover Ball
AIS Intake with fender sleeve
CCV Reroute - Hutch and Harpoon
Dieselsite Coolant Filter
Manefine inline PS and Trans filters
Bilstein shocks
stevestroke08 is offline
post #3 of 21 (permalink) Old 12-09-2010, 11:33 PM
Diesel fanatic
GMAN1's Avatar
All 6.4s come with a block heater. Some trucks came from the factory without the cord because of the options list that was chosen. If it has the cord it will be tucked behind the passenger side front bumper by the tow hook. It will have a round cover over the prongs so it might look like a wiring harness if you dont look carefully.
2009 F250 Lariat cc/sb sterling gray - Just a couple of bolt on mods.
GMAN1 is offline
post #4 of 21 (permalink) Old 12-09-2010, 11:57 PM Thread Starter
Bushwakd's Avatar
If it does not have the cord where is the location where it will connect to the heater if a cord is bought?
Bushwakd is offline
post #5 of 21 (permalink) Old 12-10-2010, 12:31 AM
<--Under the Knife Again
Blcksmk08's Avatar
Its in the passenger side block right above the starter. it is very tight and kinda a pain to get to but its there. i put the cord in mine.
2008 Hand Shaker MPD Batmo Eliminator Compounds 66 80
Blcksmk08 is offline
post #6 of 21 (permalink) Old 12-10-2010, 11:33 AM Thread Starter
Bushwakd's Avatar
Thanks, for the good info. I will pass the information on to the guy.
Bushwakd is offline
post #7 of 21 (permalink) Old 12-11-2010, 02:08 AM
zabeard's Avatar
anyone have a Ford Part number on this Cord?
2003 Ford Ranger on 42s, COs, Caged, Fully built 5.4L DOHC, blah blah
1997 F350 CCLB 4WD Auto. Basics 4" Exhaust and 6637 filter.
zabeard is offline
post #8 of 21 (permalink) Old 12-11-2010, 02:19 AM
Blcksmk08's Avatar
International part number ZBL3600008 made by Zerostart.Zerostart part number 706051. i couldnt find the ford number but i had the International part number. hope this helps
post #9 of 21 (permalink) Old 12-11-2010, 02:42 AM
Super Sparky
fine69's Avatar
You can save yourself some money and buy it at an International dealer instead of a Ford dealer.
2009 F350 4x4 CCLB Job 2
fine69 is offline
post #10 of 21 (permalink) Old 12-11-2010, 02:43 AM
powr2stroke's Avatar
6.4 superduty block heater harness Ford Part #7C3T-6B018-B
edit; I just found my invoice, I paid $87.41 @ Ford dealer for price comparison
powr2stroke is offline
Human Verification
