Coolant and coolant additives - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 12-08-2010, 05:39 PM Thread Starter
Draind the radiator to do an egr delete truck has 7000 miles on it. Got the ole stuff in a clean bucket. About 4 gal the book says it holds 7.5 gal.and it takes an additive. Should I finish getting it all out? Or just add. Is this something special or is it dex cool? Orieleys dex cool don't have fords spec.number m97b51-a1. An what about the additive?
hopperwagonbob is offline
post #2 of 9 (permalink) Old 12-08-2010, 05:57 PM
pog
pog's Avatar
Re: Coolant and coolant additives
Im not sure about the additive but the coolant is ford premium yellow. You can get some stuff at walmart the name starts with a z. It will be yellow coolant. And 50/50 mix it with distilled water. I have heard of people changing the coolant type to red or whatever but dont know too much about that.
pog is offline
post #3 of 9 (permalink) Old 12-08-2010, 08:45 PM Thread Starter
Rudys said to use the m/c and use the additive . 14 bucks a gal at ford additive was 7.
post #4 of 9 (permalink) Old 12-08-2010, 08:54 PM
pog
pog's Avatar
Whats the additive called?
pog is offline
post #5 of 9 (permalink) Old 12-09-2010, 03:04 AM
zabeard's Avatar
mc? also what is the additive?
Only thing i have read on Ford's sites is running Motorcraft Gold coolant with bittering agent. Nothing more.
2003 Ford Ranger on 42s, COs, Caged, Fully built 5.4L DOHC, blah blah
1997 F350 CCLB 4WD Auto. Basics 4" Exhaust and 6637 filter.
zabeard is offline
post #6 of 9 (permalink) Old 12-09-2010, 03:52 AM
pog
pog's Avatar
Mc i think he means motorcraft. I have never heard of an additive for the coolant
pog is offline
post #7 of 9 (permalink) Old 12-09-2010, 11:42 AM
zabeard's Avatar
Only thing I can think of is iron cleaner but you shouldn't use that all the time You only use that before a system flush.
zabeard is offline
post #8 of 9 (permalink) Old 12-09-2010, 12:30 PM Thread Starter
Mc8 is the part number. And it is motorcraft. Look at your suppelmental diesel owners manual. I believe it's fo the alkalinity. Bottle says 4 oz per gal of cooling. It also says to use test strips to determine if additive is required.test kit is called rotunda 328-00001 or 328-00006.
post #9 of 9 (permalink) Old 12-09-2010, 03:33 PM
You don't need an additive yet with only 7k miles. I would just filter the original coolant and put it back in.
2012 F-150 XLT Ecoboost SuperCrew 6.5' 4x4
cartmanea is offline
Human Verification
