Serpentine Belt, how hard to change? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 7 (permalink) Old 06-18-2010, 10:16 PM Thread Starter
Was PSD0389
Matt_P's Avatar
Ok so among the other things the dealer is fixing on my truck right now they told me that my serpentine belt needs to be replaced.
They want 320 to do it. Id really like to avoid spending that but Ive looked before and it doesnt look too easy to do on a 6.4. Nothing compared to when I replaced one on my 7.3
So my question is how hard is it to do. Will I just be throwing tools from being frustrated or is it not too bad?
Thanks
03 F-350 CCLB King ranch undergoing a 6.0 delete
99 Fummins- SOLD
95 F250- SOLD
08 6.4- Totaled 12/19/10
Matt_P is offline
post #2 of 7 (permalink) Old 06-19-2010, 12:13 AM
POWERSTROKER's Avatar
Re: Serpentine Belt, how hard to change?
What else is the dealer fixing?
Ita a PITA if you have never done one
Early 1999 (4/98) 7.3, Automatic, f-250 superduty, 4x4, crewcab, shortbed.
CCV Mod
knn intake
banks exhaust
banks power elbo
banks turbo housing
big head waste gate-disconnected
Tuning by
4 gauge pod with DiPricol pyro, boost, trans temp, HPOP
POWERSTROKER is offline
post #3 of 7 (permalink) Old 06-19-2010, 01:15 AM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
If its anything like the 6.0 I bet iits a royal PITA
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
post #4 of 7 (permalink) Old 06-19-2010, 01:35 AM
BFT
IM OUT!!!
BFT's Avatar
looks like they are taking you for a ride bud!
he's got a forehead like a drive-in movie theater
BFT is offline
post #5 of 7 (permalink) Old 06-19-2010, 01:35 AM
<<< just like that......
SootRoller's Avatar
Start by removing the top half of your fan shroud {two 8mm bolts on the powersteering reservoir [remove the pwr. strng. line that is in the plastic bracket on the side of the reservoir first], the other two are on either side of the shroud, about midway down} then GENTLY remove the top half. It will be a tight squeeze so take your time. Second, you need to remove your fan shroud. It is held in place by two 13mm nuts {top two} and two 13mm bolts on the bottom. Third step, you need to remove your fan. First, place a fender cover over the rear or your radiator. Second, disconnect your fans electrical connector. Next, going clockwise {when standing in front of the truck, looking at the hood, to the right}, take your fan off. Place one hand under the clutch to catch it when it comes off. Then GENTLY!!!! lay it against your radiator and let it lay. You should then have enough room to fa-niggle it. Fourth, remove your belt. You tensioner is a 3/8th drive. It is very easy to release the tension, however, ther is no relief clip for it. You will have to hold tension on it with one hand and remove the belt from whatever pulley you can get to easiest. To install, thread the belt according to the diagram on your crossbrace. It will be a bit of fun to put it back on because you have to hold tension on it while attempting to thread it on the one pulley left...however, it actually isn't a bad job at all. Just a pain to get to the belt itself. If I were you, I'd do it myself as it is definetly easier than $320.00 out of the pocket. Plus, you will learn a little about your truck during....you'll also make a vow to kill any engineer who had anything to do with the belt placement on the 6.4. Sorry about the novel man
~I shoot the early bird, that's how I get the worm~Weezy
SootRoller is offline
post #6 of 7 (permalink) Old 06-19-2010, 01:37 AM
SootRoller's Avatar
It will make you beg to do a 6.0 belt...your first time, it really is that much fun.
post #7 of 7 (permalink) Old 06-19-2010, 04:06 AM Thread Starter
Was PSD0389
Matt_P's Avatar
Thanks for taking the time to write all that! IT definitely seems like a pain in the ass but cant be worse than pulling a stock turbo off an OBS
See Im kinda thinking that since when I rode in the truck with another tech a while ago we both thought the squeaking was coming from the back left of the engine.
But I guess it could be the belt, I dont know what to think. I mean it all started after my head gaskets were done, the squeaking didnt happen til right after I picked it up from the other dealer.
New FRP sensor and harness
Ive only done one on my OBS
99 Fummins- SOLD
95 F250- SOLD
Matt_P is offline
Human Verification
