Anyone Had 2010 6.4 Problems???? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 51 (permalink) Old 06-08-2010, 11:44 PM Thread Starter
The title says it all. Just curious if anyone has had problems with there 2010 and if so what problems did you have?
Strokeme2010 is offline
post #2 of 51 (permalink) Old 06-09-2010, 12:24 AM
Re: Anyone Had 2010 6.4 Problems????
I dont have a 2010 but I do have a Job 3 2008 thats had its fair of problems. Its been to the dealer about 5 or 6 times for my memory seats and air conditioning not pushing cold air like it should. Just picked it back up tonite and they said it was all good but again its not to bad thay were closed or I would have given them an ear full. The other problems would be loss of power and surging sometimes. I would love to know how to post on this damn site. What problems have you had.
btaylor08 is offline
post #3 of 51 (permalink) Old 06-09-2010, 12:30 AM
kingranch1's Avatar
I have a 2010 w/approx 3,500 miles and no issues. I thought I had a oil leak but it must of been the oil changer at the Ford store splashed oil on bottom side of my bell housing like a rear main seal leak. But I cleaned it up and no issues.
2010 F-350 King Ranch Platinum White SRW-S/B-FX4-Loaded
All stock for now but.......
Traded in....
2006 F-350 King Ranch C/C SRW 4WD 6inch Fabtech
Radius Arm lift w/Fabtech traction bars. 37x13.50x20Toyo M/T'S Moto Metal 956's MBRP 4" turbo back no kitty,AFE,Accufab elbow, SCT livewire-Tuned by none other than Eric !!
kingranch1 is offline
post #4 of 51 (permalink) Old 06-09-2010, 01:38 AM
POWERSTROKER's Avatar
Any part on any vehicle can fail at anytime, that being said...
At the dealer I work at we havent had many issues with 2010s, a few radiators, some oil leaks (usually front cover area), one with a leaking hose on the horizontal egr cooler, and one with a messed up A/C compressor, i cant remember evrything, but nothing major yet.
Early 1999 (4/98) 7.3, Automatic, f-250 superduty, 4x4, crewcab, shortbed.
CCV Mod
knn intake
banks exhaust
banks power elbo
banks turbo housing
big head waste gate-disconnected
Tuning by
4 gauge pod with DiPricol pyro, boost, trans temp, HPOP
POWERSTROKER is offline
post #5 of 51 (permalink) Old 06-09-2010, 01:43 AM
gracing's Avatar
Ac not working and injector.
SWAMPS DIESEL PERFORMANCE
DIESEL INNOVATIONS
PERFORMANCE TRUCK PRODUCTS
EMPIRE DIESEL PERFORMANCE
gracing is offline
post #6 of 51 (permalink) Old 06-09-2010, 01:50 AM
Mpoage's Avatar
my uncle bought a 2010 about a month ago and he has 2500 miles on it already and not a problem.
2007 Ford F-250 Lariat Outlaw 4X4
SCT X3 Tuned By Innovative Diesel
Straight Piped
Edge Insight
Mpoage is offline
post #7 of 51 (permalink) Old 06-10-2010, 11:49 AM
dieseljosh07's Avatar
no problems with a 2010 yet. but i'm now up to 14 short blocks or complete engines on 08-09 trucks, i'm sure I'll have a 2010 that needs a engine before long.
dieseljosh07 is offline
post #8 of 51 (permalink) Old 06-10-2010, 01:27 PM
Hi...new here.
I have a 2010 F250 CC SB FX4 Lariat.
What is the number one reason you have seen regarding failures? Cooling issues, fuel issues, abuse, lack of PMs, etc.
tjbrowder is offline
post #9 of 51 (permalink) Old 06-10-2010, 04:48 PM
the #1 cause of engine damage I have seen is overfilled crankcases from a internal fuel system leak. once the oil level is overfilled the engine is overfueled from oil coming thru the crankcase vent and the charge air cooler. this then will start melting the left bank of pistons and can burn the tip off of the glow plug. also if on of the egr coolers leak it can flood the cylinders with enough coolant to hydro-lock the engine and bend connecting rods
post #10 of 51 (permalink) Old 06-10-2010, 04:56 PM
<-MONEY PITT!!
ifitssmokinitsstrokin's Avatar
2010 ccsb 3*** miles Cant remember right now...Erics tunes dpf delete and intake no problems yet!!
2010 CCSB Afe Intake and dual exhaust
2006 CCLB F-250 Studs,Squeez,EGR delete,RR to AirDog II and a Airraid Intake & Sct Hot tunes *SOLD*
1963 Chevy Nova II 88mm turbo 408 LSX backhalved and tubbed 9.22 @ 145 @ 5000ft BUILT NOT BOUGHT!
02 Cummins ECSB 5 spd,250s,edge comp 64 over a s475.. Work Truck
ifitssmokinitsstrokin is offline
Human Verification
