Help with white smoke - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 6 (permalink) Old 04-20-2017, 04:27 AM Thread Starter
jtc
Here lately I've noticed if I get on the accelerator anything over half throttle my boost will go to 35 psi and white smoke will be coming out of the exhaust pipe and the truck will run terrible. This happens for about 10 seconds and clears up and all is back to normal. This happens about once or twice a week. Any ideas on what it could be? Truck is a 2008 deleted and Spartan tuned. All fuel filters have been changed every 2 oil changes. Oil and coolant levels are near perfect
jtc is offline
post #2 of 6 (permalink) Old 04-21-2017, 02:19 AM
Re: Help with white smoke
Are you sure it's white? White is only one thing and that's coolant going through the motor. But Grey is a bad fuel to air mixture more times then not
08f450pstroke from KY
08 F-450 King Ranch, 4x4 auto, Spartan tuned 300, DPF/EGR delete, CCV mod, S&B Intake and a few other things.
08f450pstroke is offline
post #3 of 6 (permalink) Old 04-21-2017, 10:45 AM
wackyman9's Avatar
How often does it get driven? Drain off the water separator?
-2008 Job #3 F250 CCSB 4x4
-Mishimoto Aluminum Radiator
-Peak Fleet Charge Purple Coolant
-SCT X4 Babysitter
-17" XD Addicts
-285 General Grabber AT2's
-Power Service White in the Tank
-Moog Tie Rods and Drag Arm
-Drilled and Slotted Rotors
-GearBoxZ DPF-R 4.0
-Flo-Pro DOC/DPF delete
-MPD CCV Kit
-Injen Evo CAI
wackyman9 is offline
post #4 of 6 (permalink) Old 04-21-2017, 05:08 PM Thread Starter
jtc
It gets driven daily I'll try draining it and see what happens
jtc is offline
post #5 of 6 (permalink) Old 04-21-2017, 09:33 PM
Smoke is turbo controlled,,pretty much? White not real good. I get white smoke at an idol, but my ccv reroute has caused that. I'm pretty sure.. Never did it before. Watch your EBP, see if is relative to the boost.. The EBP sensor Can? cause some dumb stuff... Just something else to look at.. Cause white is not good.
My09Ride is offline
post #6 of 6 (permalink) Old 04-23-2017, 02:03 AM
Fummins90's Avatar
I second watching ebp sensor reading and voltage as well.
Fummins90 is offline
Human Verification
