"Police Dark" Headlight feature - PowerStrokeNation : Ford Powerstroke Diesel Forum
 2Likes
post #1 of 18 (permalink) Old 01-09-2017, 09:23 PM Thread Starter
Luddite in Charge
Mr_Andy's Avatar
Now that the first of these 6.4's are going on 10yrs old, has anyone stumbled on a non-dealer way to eliminate the annoying 'headlight-upon-unlock' feature? Specific tunes, maybe even easier JUST SNIP A WIRE?
Mr_Andy is offline
post #2 of 18 (permalink) Old 01-10-2017, 12:40 AM
Administrator
Zmann's Avatar
Re: "Police Dark" Headlight feature
Fixed it
masakimm likes this.
DTR's Donation page
RIP DTR Ron
you are missed and will live on through your great video contribution to the DIY community
Zmann is offline
post #3 of 18 (permalink) Old 01-10-2017, 08:06 AM Thread Starter
Luddite in Charge
Mr_Andy's Avatar
Lol, just drive with a spotlight out the window for a headlight.
Mr_Andy is offline
post #4 of 18 (permalink) Old 01-10-2017, 01:12 PM
wackyman9's Avatar
Meaning that your headlights come on when you hit the unlock button on the fob?
-2008 Job #3 F250 CCSB 4x4
-Mishimoto Aluminum Radiator
-Peak Fleet Charge Purple Coolant
-SCT X4 Babysitter
-17" XD Addicts
-285 General Grabber AT2's
-Power Service White in the Tank
-Moog Tie Rods and Drag Arm
-Drilled and Slotted Rotors
-GearBoxZ DPF-R 4.0
-Flo-Pro DOC/DPF delete
-MPD CCV Kit
wackyman9 is offline
post #5 of 18 (permalink) Old 01-10-2017, 01:46 PM
Moderator
Sbluke55's Avatar
Only way I can think of is ae or possibly forscan.
01 f-250, Standard
Sbluke55 is offline
post #6 of 18 (permalink) Old 01-10-2017, 03:29 PM
79jasper's Avatar
^ that. Or possibly carista.
Sent from my SAMSUNG-SM-G935A using Tapatalk
79jasper is offline
post #7 of 18 (permalink) Old 01-11-2017, 05:34 AM Thread Starter
Luddite in Charge
Mr_Andy's Avatar
Yeah, the fob 'unlock' does it. Using the key in the door doesn't trip it.
Mr_Andy is offline
post #8 of 18 (permalink) Old 01-11-2017, 11:58 AM
Master BS'er
jamiesaun's Avatar
That would make it a function of the body control module. It's probably the only control wire to that relay and it uses software to figure out when to turn them on, in which case you definitely would not want to cut it.
If it has separate circuits to control the lights, then you could cut it. The problem with that is almost every circuit has a bias in it nowadays. Exactly what a bias is; is just a voltage used by the computer or module for sensing, that's it, that's all it does. It's simply used so the module knows that the circuit is intact. It expects to see 12v at the end of this wire all the time, and if it doesn't, it knows there's a problem and will alert you of a problem, or store a code or whatever have you. it's simply an integrity check of the circuit, a way of monitoring the circuit.
So, if the wire is cut, the bias will not be seen and it'll either store a code for it, or worse, ding at you every so often...which is probably more annoying than the lights in the first place. If I can manage to remember I'll pull up a diagram and see how they're wired at work.
Year make and model?
Jamie.
p.s...I'm pretty frickin awesome!
jamiesaun is offline
post #9 of 18 (permalink) Old 01-11-2017, 06:53 PM Thread Starter
Luddite in Charge
Mr_Andy's Avatar
08 XLT SC
Mr_Andy is offline
post #10 of 18 (permalink) Old 01-11-2017, 08:17 PM
Because I can!!!
Thatchevyguy's Avatar
Been there done that. And it was about 0 degrees so my hand was a little bit chilly
Zmann likes this.
97 F350 cclb
Lots of go fast parts
Dark candy apple now- twas a 7 different color project truck
5spd swap with SBC
And a 98 Chevy k1500 dd - leveled and looks pretty but is slow as hell!!
OBS FOR LIFE!!!!
Thatchevyguy is offline
Human Verification
