How many quiarts of oil in 6.4 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 11-07-2009, 01:59 AM Thread Starter
giving my truck a oil change tommorow how much oil does the the 6.4 hold..
Thanks
2008 Harley F250 is offline
post #2 of 10 (permalink) Old 11-07-2009, 02:06 AM
WWDD
Dzchey21's Avatar
Re: How many quiarts of oil in 6.4
15 quarts bro
couple trucks one fast one not
Dzchey21 is offline
post #3 of 10 (permalink) Old 11-07-2009, 02:08 AM Thread Starter
Thanks DZ...
At what cetain mile stages are you suppose to service certain stuff like rear transfer case tranny oil?
post #4 of 10 (permalink) Old 11-07-2009, 02:11 AM
WWDD
Dzchey21's Avatar
Ill have to look in the manual i think transfer case is 75k and i know that the rear diff is over 100k its in the owners manual ill have to look, i think it says 50k on the trans as well.
Most people are servicing engine around 5k and fuel filters every other oil change, ill look in my manual later and post exact numbers.
Dzchey21 is offline
post #5 of 10 (permalink) Old 11-07-2009, 02:23 AM
fordpowerf450's Avatar
Originally Posted by 2008 Harley F250 View Post
Thanks DZ...
i think trans is at 100k. depending on how you use your truck would probly be a good idea to go 50k. thas all i know tho.
08 6.4 cc/lb.
2006 6.0 just stock..
1960 f100, 12v project.
fordpowerf450 is offline
post #6 of 10 (permalink) Old 11-27-2009, 09:51 PM
Lunchbox
First diesel. Any good "how to's" to change oil?
2009 F250 CC 4x4 Lariat
6.4 L
Spartan tuned
4" exhaust dpf delete
Lunchbox is offline
post #7 of 10 (permalink) Old 11-27-2009, 09:54 PM
Haters Gonna Hate
Fordfreak4life's Avatar
drain it with the engine warmed up to temperature and dont get any of that hot sh*t on ur arm... lol.... no tricks really... lube the orings on your filter lids with a lil oil when u go back together to keep them from tearing and help them seal up better...... welcome to the diesel world
Fordfreak4life is offline
post #8 of 10 (permalink) Old 11-28-2009, 03:46 AM
Laces Out
bigrpowr's Avatar
around 15 quarts.
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #9 of 10 (permalink) Old 12-02-2009, 05:06 PM
SilverDiesel08's Avatar
A little advise, remove your oil filter and let it drain and then drain the pan and let them both drain for a good time. This gets most of the used oil out compared to if you dont change your filter untill after you put the drain plug back in.
Also on a truck with the DPF system still on, 14 quarts are best for during regen, a small amount of fuel passes the rings in the combustion chamber and with 15 quarts it will be over full.
SilverDiesel08 is offline
post #10 of 10 (permalink) Old 12-03-2009, 12:09 AM
thieungu is offline
Human Verification
