6.4 front seal leak...3rd time in.... - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 10-09-2009, 05:41 AM Thread Starter
RKracing's Avatar
Front seal leak ....small leak but still.....3rd time in 15,000 miles.....What the hell is going on? Any body "been there-done that" ?
RKracing is offline
post #2 of 13 (permalink) Old 10-09-2009, 06:01 AM
Laces Out
bigrpowr's Avatar
Re: 6.4 front seal leak...3rd time in....
ive heard about this. mine had some residue underneath the crank but never a leak. i wonder why your's would leak more than once!!!
08' F250 4x4 w/ 3:55's
bigrpowr is offline
post #3 of 13 (permalink) Old 10-09-2009, 02:43 PM
fbilly420's Avatar
Do you know if the are replacing the sleeve that goes over the end of the crank with the new seal? I have heard that if it is not replaced with the seal it is more likely to leak.
Or they could be installing it incorrectly I just finished the 6.4 courses through Ford.
2001 F250, CCSB, 4X4, Auto, Forged rods
Lots of go fast parts and still slow.
2001 F250, STD cab, 2WD
Frame is a little shorter now
workin on body
engine build underway
fbilly420 is offline
post #4 of 13 (permalink) Old 10-09-2009, 10:39 PM
Stroken it 7.3,6.0,6.4
weekendwarriorfsw32's Avatar
Is to much boost causing this?
08 F 450 King Ranch 6.4
Elite Race trans, Spartanized, ARP, Icon 4.5 on 35's, RDP boots, HID'S, OUO ladder bars, 3" I/C pipe
04 X 6.0
08 tow mirrors, ARP studs, RDP boots.
01 X 7.3, Dp, Cass 238/80 Hybrids, Terminator Dual pumps, TNBB holding on for dear life @40+psi, TE thermostat, ARP studs, Fluidampner, RDP 6637, RDP boots
weekendwarriorfsw32 is offline
post #5 of 13 (permalink) Old 10-11-2009, 06:34 PM
Mine did this when I was out doing the learning process for my new TCM/275, but it was just a small amount, not enough to even make it drip, wiped it off and so far it hasn't done it again, I thought it was from doing the learning process as I had my foot into it real hard and most likely my boost was real high during this process, right now I'm not going to worry about it as I don't normally run my truck that hard, cleaned it up real good and just watching.
cbenn is offline
post #6 of 13 (permalink) Old 10-14-2009, 11:26 PM Thread Starter
RKracing's Avatar
OK...My bad....Not a dripping leak but heavy residue.....about to leak...you decide...will post pics as soon as I can.
RKracing is offline
post #7 of 13 (permalink) Old 10-15-2009, 12:39 AM
aggie's Avatar
Ive seen it too. Happened in the first 1000 miles. was replaced and hasnt leaked since. If its anything like a rear main on a 7.3, you have to replace the seal and the ring together.
[SIGPIC][/SIGPIC]
aggie is offline
post #8 of 13 (permalink) Old 10-16-2009, 01:57 AM Thread Starter
RKracing's Avatar
Here's 2 pic's.
RKracing is offline
post #9 of 13 (permalink) Old 10-16-2009, 02:03 AM
WWDD
Dzchey21's Avatar
mine looks pretty much just like that, either high boost or a poor seal design is causing it, im not taking mine in untill it leaves a drip on the ground
couple trucks one fast one not
Dzchey21 is offline
post #10 of 13 (permalink) Old 10-16-2009, 02:24 AM
roughneck0913's Avatar
the seals on a 6.4 are designed to be put in dry there teflon coated the tech putting seals is is probably coating seal or crank thus ruining the seal and it will leak they need to put seal in dry and clean crank and use the special seal driver should seal then just my .02
roughneck0913 is offline
Human Verification
