AC problems! Not blowing strong. - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 10 (permalink) Old 07-27-2012, 07:33 PM Thread Starter
HTFU
Evofit300's Avatar
AC system won't blow strong enough to cool the cab down. I took it in to a local mechanic and had them do an AC check. Evaporated system, recharged (was 4 oz low), tested temps (was blowing around 50 degrees), and was told to check a TSB on the DATC. Bought another DATC and plugged it in and no change, so returned it. It's blowing the same out of both sides. Not coming out of the defrost or the floor when set to front vents (just as it is supposed to).
Not sure what else it can be. You can hear it blow harder as you turn the fan up, just blows the same on high as if it were on a medium setting.
Thanks in advance for help.
2008
F250 CC SB SRW Lariat 4x4 6.4L
Ranch Hand Deer Tenderizer
S&B Cold Air Intake
Mini Maxx with DPF/EGR Delete
18" Weld Velociti with 35x12.50 Toyo Open Country MT
Evofit300 is offline
post #2 of 10 (permalink) Old 07-28-2012, 04:20 PM Thread Starter
HTFU
Evofit300's Avatar
Re: AC problems! Not blowing strong.
Have seen other problems with AC, but seems like this one isn't common. Need to figure out a direction to go next.
2008
S&B Cold Air Intake
post #3 of 10 (permalink) Old 07-30-2012, 04:50 PM
greaseltn's Avatar
You may need to take the fan out and see if a mouse built a nest in the cage. I've seen it before, but usually on a truck that spends alot of time parked.
greaseltn is offline
post #4 of 10 (permalink) Old 07-30-2012, 05:39 PM
TimmyaleX
DATC?
Support Blue Collar Workers
-2008 F-350 XLCCLBSRWZF6
-Fast Idle Switch
-5" DP back
-Innovative livewire
-No Limit
-Newton Fat Boy Traction Bars
-Ebay Leveling Kit
-ICON adj. Trac BAr
-NITTO Terra Grapplers
-Flo Pro EGR delete
-South Bend 3250
-Spartan
-Lab Pit "Stella"
HD-tech-NH is offline
post #5 of 10 (permalink) Old 07-31-2012, 05:59 PM Thread Starter
HTFU
Evofit300's Avatar
Dual Automatic Temperature Control
It's the control unit that sits below the radio.
Have recently replaced the belts, tensioner, and idler pulleys, and haven't seen any creature nests. Even sprayed out the fins on the radiator.
2008
S&B Cold Air Intake
post #6 of 10 (permalink) Old 07-31-2012, 06:38 PM
wynndaddy's Avatar
My work truck did this and it had sucked a plastic bag up from the floor and was blocking flow . It would try to change but couldn't complete the cycle . You could hear it blowing hard behind the dash .
1997 cc swb 4x4
wynndaddy is offline
post #7 of 10 (permalink) Old 08-07-2012, 12:49 AM Thread Starter
HTFU
Evofit300's Avatar
I ran an inspection camera through the vents and found no obstructions .
I read that the evaporator is likely a cause in dusty areas. I bought the truck from Tennessee and there was alot of fine tan dirt in the air filter and all over the truck. So I'm assuming it would probably be beneficial to clean out the evaporator.
Here's the problem, I can't find any good instructors on how to get to it and open it up. Any help would be appreciated.
2008
S&B Cold Air Intake
post #8 of 10 (permalink) Old 06-17-2013, 01:06 PM
johnnyroastbeef's Avatar
did you ever figure out this issue? My AC seems to be in the same situation not blowing very hard. Just wondering if you ever fixed it and what you determined the cause to be. thanks.
-'09 F350 CCSB, SRW, 2.5" leveling kit, ICON adjustable track bar, Alradco Radiator, 35/12.5R20 Nitto Trail Grappler, Detroit TrueTrac
johnnyroastbeef is offline
post #9 of 10 (permalink) Old 12-02-2014, 01:11 AM Thread Starter
HTFU
Evofit300's Avatar
Hopefully you have fixed the problem. I haven't been on in a while. For others looking for the resolve. My evaporator was dirty.
I removed the glove box and behind it is a large black box. To save myself the trouble, I cut about a 3"x3" square in it with a razor knife. I used a/c condenser cleaner (from home depot for home a/c units). I sprayed that inside and let it sit for a couple minutes. then with a spray bottle of water rinsed it all out. Make sure it drains out of the drain tube that sits behind the air filter box. If not, stick something in there to unclog it. I cut out a piece of aluminum to cover the whole, ran a bead of silicone around it, a screwed it on. Has held up for over a year with no problems.
2008
S&B Cold Air Intake
post #10 of 10 (permalink) Old 08-18-2015, 06:13 PM
Where did you cut the hole in the middle of to the right or left side?
Magta is offline
Human Verification
