6.4 belt change - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 4 (permalink) Old 11-27-2011, 09:38 PM Thread Starter
6.4 belt change
if i put soap on it the squeak stops so i figured it was idler pulley so i changed that without taking the belt off. it did not stop so i guess i need a new belt as the tensioner pulley appeared to be ok . how hard is it to diy??? and if it is a shop job what should i expect to pay ?? only 50k on the truck one would think the belt would last longer but time to open wallet from what i hear 4.5 hr and 89 for the belt this sound correct ???? any recommendation on belt brand ???
doublesrtroker is offline
post #2 of 4 (permalink) Old 11-27-2011, 10:15 PM
Roamer
Evil Diesel's Avatar
Re: 6.4 belt change
If it is a pulley, Ford just replaced my tensioner and idler pulley under the 100k powerstroke warranty
99.5 f350 (sold but greatly missed).
10 F350 with the usual go fast parts
Evil Diesel is offline
post #3 of 4 (permalink) Old 11-28-2011, 12:29 AM
Cab on installer
White_monster's Avatar
Re: 6.4 belt change
It's about a 30min job to change the main belt. To change ac belt, a few hours.
2008 F350 CCLB
Elite Max-Power turbos are only the start
White_monster is offline
post #4 of 4 (permalink) Old 11-28-2011, 12:54 AM
mandkole's Avatar
Re: 6.4 belt change
50K is about right before the belt ribs have worn enough on a misaligned drive. If the squeak or chirp stops after running some soap on the belt ribs, you've isolated that misalignment is your issue. Its in the belt path and unless the misalignment is obvious, they are not easy to troubleshoot and its often easier to just change the belt when it gets pissed. Tolerance stack affects all of the brackets, pulley/accessory location, etc.
Swap the belt and it should stop but will come back within 50K miles. Belts last far longer than that (we have heavy truck accy drives that last 250K), but unless the alignment issues can be found, it is what it is.
Our guys in our replacement group at Gates are always putting new stuff on the web so perhaps there's something there.
2000 F250 CCSB-- GT4294R, 250/100s, Dahl/Fuelab, PHP, scan gauge, stock 17* pump
1994 F250 4x4 SC (sold)
1997 F250 CCSB 2wd (sold)
mandkole is offline
Human Verification
