08 6.4 hesitating - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 19 (permalink) Old 09-25-2011, 06:23 AM Thread Starter
Unhappy 08 6.4 hesitating
i just bought an 08 f350 lariat with a 6.4 and on the 200+ mile trip home it started
hesitating at about 2200 rpm. at first it wouldnt go over 35mph but then i let off and
eased back onto the throttle and it got to 75mph and wouldnt go over 2500 rpm.
my first thought was the fuel filter so i changed it when i got home and it ran great for
about 20 miles now its doing it again. if it does and you stop and put it in park it
wont rev over 2500 and when it hits 2500 the truck shakes and the engine sound
makes a real loud like womp wompwomp womp and almost popping type noise. if
you ease into it you can get it to around 75mph. but if u hammer it your luck to hit
30. it had a code that said that the fuel pressure was too high. any ideas as to what
would fix the problem?
smalltown6.4 is offline
post #2 of 19 (permalink) Old 09-25-2011, 06:24 AM
Re: 08 6.4 hesitating
Injector, Fuel sensor, Id invest in a tuner and DPF delete if i was you. the DPF is what ruins these trucks
08murderedout is offline
post #3 of 19 (permalink) Old 09-25-2011, 01:11 PM
itsdieselornothing's Avatar
yea i would defiinatly invest in a tune and dpf delete i just did it to my truck and wow my truck runs rlly good and gets good fuel mileage good luck
itsdieselornothing is offline
post #4 of 19 (permalink) Old 09-25-2011, 01:24 PM
skobiak's Avatar
Did u change both filters and also drain the water separator?
skobiak is offline
post #5 of 19 (permalink) Old 09-25-2011, 02:08 PM
LowDog63's Avatar
hopefully its not what happened with mine. The HPFP disintegrated causing metal shavings to get in the fuel system. known problem with these trucks. The entire fuel system had to be replaced. Luckily it was under warranty...otherwise the dealer said it would of cost $8K. Hope this is'nt the case for you but their are several forums about this issue. Good luck man.
LowDog63 is offline
post #6 of 19 (permalink) Old 09-25-2011, 04:02 PM Thread Starter
yeah man i changed both filters. the water separator is the filter on the on chassis right? if so yes i drained it before i changed the filters.
post #7 of 19 (permalink) Old 09-25-2011, 07:12 PM Thread Starter
does this sound like the highpressure/injector pump?
post #8 of 19 (permalink) Old 09-25-2011, 09:46 PM
fordpowerf450's Avatar
maybe a plugged up dpf? that could take some power away have you checked the oil level to see if its high or diesely? just some thoughts i would try changing the injection pressure sensor also could be reading high telling it to cutout full..
08 6.4 cc/lb.
2006 6.0 just stock..
1960 f100, 12v project.
fordpowerf450 is offline
post #9 of 19 (permalink) Old 09-27-2011, 03:26 AM Thread Starter
damn! i hope its not that! i aint got that kinda cash lol. i am startin to think its a bad hpfp though, the dealership said 2700 to replace it. but im thinkin it may be a sensor because it runs fine before the truck gets heated up, but once its heated up if i hammer on it or try to get the rpms above 2500 then it throws the code and wont accelerate.
post #10 of 19 (permalink) Old 09-27-2011, 04:43 AM
Well if it don't do it when it's cold then that might be a good thing.
08 6.4 cc/lb.
Human Verification
