78' F150 to a 7.3 swap? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 9 (permalink) Old 03-12-2009, 01:16 AM Thread Starter
blue99sd's Avatar
Ive seen alot of you guys swapped 7.3 and 6.0's into some nice rides. Just wondering how hard it was and what all you had to do to get a 7.3 into a 78'?
Here is a pic of my truck, it has 9" suspension lift and a body lift, and dana
60's front and rear. if I had a doaner truck engine,trans and transfer case, all the wiring what do you think?
99 PSD dually
4" lift 35' tire
4" exhaust to 6" Aussie's
K&n air filter
cc mod
Beans stage II 120hp injectors
Beans D66 turbo
ITP regulated return
updated ecm (2000 model)
reburned TS chip- 25,high idle,60,100,120,140hp
Dyno #'s 360hp and 965 ft lbs trq
blue99sd is offline
post #2 of 9 (permalink) Old 03-12-2009, 02:28 PM
JDG's #1 Fan
99F250Smitty's Avatar
Send a message via AIM to 99F250Smitty
Re: 78' F150 to a 7.3 swap?
Awsome truck, Don't know much about the swap, but if you have the money and knowledge, go for it, that would be sweet to see some coal rolling out of those stacks.
Brian
_____________________________________________
99.5 F250 Extended Cab Short box. 4x4.
99F250Smitty is offline
post #3 of 9 (permalink) Old 03-12-2009, 04:01 PM Thread Starter
blue99sd's Avatar
Yea, thats my play toy. Been in a lot of deep mud. Would love to see some smoke blowin out of it.
99 PSD dually
4" lift 35' tire
K&n air filter
cc mod
Beans D66 turbo
blue99sd is offline
post #4 of 9 (permalink) Old 03-12-2009, 10:21 PM
superdutyfarmer's Avatar
post lots of details and pics, i would love to do this to my first truck which is the same thing, but a 77
2008 F-250, 6-speed. South Bend, SCT(KEM345), Flo-pro, you get the idea
Rodney
superdutyfarmer is offline
post #5 of 9 (permalink) Old 03-13-2009, 01:47 AM Thread Starter
blue99sd's Avatar
Not doing it yet tryin to get info first. Ive found a few wrecks, just geting the money is the hard part.
99 PSD dually
4" lift 35' tire
K&n air filter
cc mod
Beans D66 turbo
blue99sd is offline
post #6 of 9 (permalink) Old 03-13-2009, 02:00 AM
i hear ya, i'm still in college and would like to build mine up when i get out of here and into the real world
Rodney
post #7 of 9 (permalink) Old 03-16-2009, 07:55 PM
HRT Performance
HotRodTractor's Avatar
I'm thinking that is a very doable swap
2006 Dmax MPI compounds
2015 VW Jetta TDI
2006 VW Jetta TDI
HotRodTractor is offline
post #8 of 9 (permalink) Old 03-16-2009, 09:59 PM
Banned
I'm thinkin you better get the 10.25/10.5 rear with the donor truck or you'll get REAL good at replacing parts in a Dana 60 rear. Same RG diameter and all..... just not the same.
As far as the swap, I would get the tranny and t-case with it. The aluminum F-series T-case is stronger/lighter than any of that old iron gear drive stuff.
If you get the vehicle chassis harness and the accelerator pedal it should be a snap to get it going. I've run my engine from a stand-alone harness before. Had it running within the day. About half a day actually.
Charles is offline
post #9 of 9 (permalink) Old 03-16-2009, 10:18 PM Thread Starter
blue99sd's Avatar
Cool thanks for the info. Ive got alot of experiance tearing the 60 apart. Ive broken I dont know how many axle shafts front and rear. Ive also relaced axles with "suposeably stronger " axles they didnt last very long either. I have seen a few guys on here do some 60s but I like the 7.3s myself.
99 PSD dually
4" lift 35' tire
K&n air filter
cc mod
Beans D66 turbo
blue99sd is offline
Human Verification
