How to remove OLD pinstripe? - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 14 (permalink) Old 06-10-2011, 01:18 AM Thread Starter
I have a 96 F250 with the 3 stripe pinstripe going down both sides. I think it's the original stripe but it needs to go. It is missing in lots of places. The problem is the parts that are missing left behind the adhesive and it is crispy and old. What I use to remove the old adhesive and the remaining pinstriping?
xbrotherx is offline
post #2 of 14 (permalink) Old 06-10-2011, 02:54 PM
No 6.0
zaairman's Avatar
Re: How to remove OLD pinstripe?
Get an eraser wheel and go slow... You don't want to burn through the paint.
Zach
2000/2006ish Ford F-250 Larryette 7.3 Powerstroke 4x4
5" Sewer Pipe Exhaust, DIY 6637 Intake, Wicked Wheel'd, De-foiled, Missing EBPV, Edge Juice with Attitude, Few leaves added here and there, 35" BFGs, 16x10 Eagle Alloys, Alpine W200
SLAPS Member #153
zaairman is offline
post #3 of 14 (permalink) Old 06-10-2011, 03:00 PM Thread Starter
I'm glad you mentioned that eraser wheel. I found some videos showing the use of that 3M Stripe Off wheel and was wondering if it would work for my case. I'll try it. Thanks.
post #4 of 14 (permalink) Old 06-10-2011, 03:21 PM
No 6.0
zaairman's Avatar
My truck used to have MILES of pin striping on it... The silver at the bottom isn't solid. It's individual pin stripes.
Eraser wheel took care of the cab when I had the bed replaced. Just go slow, you can't go balls out on the drill or you will burn the paint. You'll find the "sweet spot" speed.
Zach
SLAPS Member #153
zaairman is offline
post #5 of 14 (permalink) Old 06-10-2011, 03:26 PM
I know nothing...
joedaddy's Avatar
Removing adhesive cheaply! - PowerStrokeNation
Doesn't roll with anyone or tag along to be cool...
joedaddy is offline
post #6 of 14 (permalink) Old 06-10-2011, 03:28 PM Thread Starter
Great! Then I will get one this weekend and try it. In all honestly, the truck is old enough if I burn the paint on my test spot I won't cry about it.
post #7 of 14 (permalink) Old 06-10-2011, 04:50 PM
No 6.0
zaairman's Avatar
Don't worry about it too much... you've gotta be a real dumbass to burn all the way through the paint. But it is possible to put some marks on the clear coat... I did that on mine. Nothing that some polishing can't remove.
Zach
SLAPS Member #153
zaairman is offline
post #8 of 14 (permalink) Old 06-10-2011, 05:10 PM
Layson's Avatar
Dang, that is a lot of pin stripping..
Layson is offline
post #9 of 14 (permalink) Old 06-14-2011, 12:55 AM
60POWERSTROKE73's Avatar
When I took off the dried up/cracked pinstripe on my 03, I scraped it off with those plastic things from vato zone to "remove stripes". I used some gas to make it soft and take the remaining adhesive off. My paint still looks good so I don't think it hurt much lol
2003 F-350 Powerstroke 6.0L CC LB Lariat FX4
MBRP 4" Turbo Back- Straight Pipe Glowshift Gauges- EGT, Boost, and Trans Temp SCT X3 with Custom Tunes from Innovative Diesel 21/2" Pro Comp Leveling Kit Moto Metal 951 rims on 33" Nitto Trail Grapplers
Originally Posted by bigrpowr View Post
The 6.4 is unreliable. You want a 03-04 6.0. Best motor ford ever built.
60POWERSTROKE73 is offline
post #10 of 14 (permalink) Old 06-14-2011, 11:45 PM
Seriously, oven cleaner works great. Sounds scary but I did it on my Syclone and it was awesome and easy. Try on small area firt.
sy1616 is offline
Human Verification
