Blown Head gasket ???? 2001 7.3 - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 3 (permalink) Old 06-12-2009, 05:48 AM Thread Starter
So, where to start... Truck started running rough. Acted like hi pres oil problem. Towed in, checked oil pres, ok. #1 and #3 cylinder faults, switched inj's around, no difference. Found aerated fuel return, compression in the fuel. Installed 80hp Industrial Inj's, fixed aerated fuel. I then went ahead and installed the ITP regualted return system, very cool, Fired her up and ran beautiful !!!. I then replaced my Edge evolution with a TS 6 pos chip,,,,Ran awesome....Got it all done, took a few short test drives, all good. Loaded up, hit the Freeway and Boom!! Coolant everywhere...excessive pres in the coolant tank....Head Gasket Gone.....I was only running 32lbs of boost.....What happened ????
01' F250 stretched to a longbed. TS tunes, Industrial inj's, Banks Turbo housing, wheel and wastegate. AFE stg II. ITP regulated return system, 5" exhaust, built from chrome truck stacks w/ MBRP over the axle. Built trans with Transgo Tugger II and Banks Trans Command..Speerco intrclr....Work Truck...
DieselXXX is offline
post #2 of 3 (permalink) Old 06-12-2009, 03:22 PM
I am the juggernaut.
SevenThree's Avatar
Re: Blown Head gasket ???? 2001 7.3
I think this is def the wrong section, buddy. Might try posting this is 7.3 tech.
Will Iott -8/24/84-7/4/10
Chris Owens-4/9/90-3/12/10
99.5 doooley. swamps. murff racing. gearhead.
SevenThree is offline
post #3 of 3 (permalink) Old 06-12-2009, 05:07 PM
jaybuller's Avatar
hahah i know i know,,,,it happend to me, i think you need some studs. mine did the same thing at 35psi. i put studs in itand it holds it easy now.
2000 f250 ECSB Dually 4.10s 305/70/16, 4x4 7.3 zf6 200k miles
Php hydra chip PHP tuned! 4" exhaust, stock turbo(ww2, turbomaster wastage actuator, gutted ebpv), FRX, 160/30 sticks SB 1939-CB single clutch, home brew water setup for when i'm pulling hay through the mountains.
jaybuller is offline
Human Verification
