Drive shaft loops - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 90 (permalink) Old 01-17-2010, 05:44 PM Thread Starter
Ticking time bomb
Drive shaft loops
Let's see some pics of how you have you drive shaft loops I need to build a set befor next pulling season
groomzybanshe is offline
post #2 of 90 (permalink) Old 01-18-2010, 03:28 AM
Adrenalin Junkie
Re: Drive shaft loops
Does anyone Market these?
PSD Trav is offline
post #3 of 90 (permalink) Old 01-18-2010, 03:38 AM
OverFuelingForYourPlesure
pontiacross's Avatar
here is what I did for my u-joint shield
I am just running one loop other than that and its basicly a U bolted to one of the bed crossmembers.
Ross
2.6 modified street pulling truck "The Lone Stroke
-1996 f350, stock bottom end! swamps 400/400% injectors, swamps BFH turbo, swamps IDM, Swamps tunes, BTS oil, springs, studs, tubes, fuel system, water to air cooler, and much more...
-97 f350 4x4 CCLB tow rig
pontiacross is offline
post #4 of 90 (permalink) Old 01-18-2010, 05:26 AM
Loves OBS Trucks
MustangMatt96GT's Avatar
What is the purpose of the bolts? and doesnt the ujoint get caught on the bolts?
1997 F350 CCLB 4x4
1999 28' Classic Dominator
1996 Mustang GT with a Blown 351 with Stalled C4
MustangMatt96GT is offline
post #5 of 90 (permalink) Old 01-18-2010, 05:27 AM
Sponsor
bigjake0524's Avatar
Looks like it is on the housing so that it doesn't flop around probably.
bigjake0524 is offline
post #6 of 90 (permalink) Old 01-18-2010, 06:45 AM
yep they are screwed up against the housing behind the yoke to keep it from moveing up and down
Ross
post #7 of 90 (permalink) Old 01-19-2010, 09:28 AM
Inmate #1
RubberDuck's Avatar
Here's one set that I built.
RubberDuck
1995 F350 4x4 CC Dually-Rockee
1995 F350 4x4 Reg Cab Dually-3.0 Puller-Bobbie's Kitchen Pass
RubberDuck is offline
post #8 of 90 (permalink) Old 01-19-2010, 09:32 AM
Inmate #1
RubberDuck's Avatar
Another set I built on a single rear shaft truck.
RubberDuck
post #9 of 90 (permalink) Old 01-19-2010, 09:37 AM
Inmate #1
RubberDuck's Avatar
And just cuz I'm bored, here's the first set I ever built.
RubberDuck
post #10 of 90 (permalink) Old 01-19-2010, 02:18 PM
Sponsor
What size pipe do you use? Did you just cut it in half and weld flanges on to bolt through? Thanks.
Human Verification
