my yamaha yfz 450 wont start - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 13 (permalink) Old 04-17-2010, 05:57 PM Thread Starter
USMCpoolee's Avatar
2007 yamaha yfz 450 will not start. It cranks over but does not want to start.
so far today i have
-charged battery
-dumped old gas and put new in
-changed spark plug
-cleaned air filter
and it is still not starting? Anyone know anything about the yamaha yfz ?
USMCpoolee is offline
post #2 of 13 (permalink) Old 04-17-2010, 06:06 PM
justintimemoto's Avatar
Re: my yamaha yfz 450 wont start
take the carb apart and clean it, is it getting spark? is it getting gas? need more information your two main things are is it gettin gas and is there spark start there
sucperchips flashpaq, banks ram air, 4"mbrp straight piped rcd egr delete leveled
justintimemoto is offline
post #3 of 13 (permalink) Old 04-17-2010, 06:09 PM Thread Starter
USMCpoolee's Avatar
dont think its getting spark it is getting gas tho because we took the fuel line off and drained all the gas out of the tank
post #4 of 13 (permalink) Old 04-17-2010, 06:10 PM Thread Starter
USMCpoolee's Avatar
how do u check the stator or restistor or something
post #5 of 13 (permalink) Old 04-17-2010, 06:19 PM
bigaF250's Avatar
The stator works as a altenator for your battery so that wont be you spark. you may have a busted spark plug wire but I doubt that. Just sittin there holdin the wire in your hand with no plug on it and turnin it over its not make a little clickin noise at all?
99 Ford F-250 8" skyjacker, 38/15.50-18, custom 4" exhaust in to 6" aussies, And much more----SOLD
08 Ford F-250 FX4: Tunes by Eric on SCT, 5" Flo-Pro, AFE stg 2, 20x10 -44mm offset Fuel Hostage wheels, 325/60r20 Nitto Terra Grapplers
560HP 1089TQ SOLD
SWCR POWERSTROKE MEMBER #29
bigaF250 is offline
post #6 of 13 (permalink) Old 04-17-2010, 06:27 PM Thread Starter
USMCpoolee's Avatar
yes there is a little clickin noise after i crank it it clicks but still trys to crank.
Just my luck everything i buy usally ends up breaking.
post #7 of 13 (permalink) Old 04-17-2010, 06:31 PM
bigaF250's Avatar
well then your gettin spark. pull your carb and clean it like stated above then go get 2 gallons of 111 race fuel and mix it with 3 gallons of 91 octane. we had to do that with our race bikes every spring. it cleans em out
560HP 1089TQ SOLD
bigaF250 is offline
post #8 of 13 (permalink) Old 04-17-2010, 06:36 PM Thread Starter
USMCpoolee's Avatar
so you guys think its just the carb is dirty or what.. The motor cranks and the battery makes a lil clickin noise
post #9 of 13 (permalink) Old 04-17-2010, 06:40 PM
bigaF250's Avatar
More then likely. especially if you didnt winterize it. change all the fluids and get some good stuff in there and she should fire right up. maybe also go have the valves shimmed and other than that you should be able to do the rest. on the yfz450 the hardest part to tune in on the carb is the pilot screw its really not bad it just gets frustrating. and you'll have to pull a little plug to get to it.
560HP 1089TQ SOLD
bigaF250 is offline
post #10 of 13 (permalink) Old 04-18-2010, 12:58 AM Thread Starter
USMCpoolee's Avatar
how hard is it to remove and clean the carb
Human Verification
HTML code is On
