DT466E Mods - PowerStrokeNation : Ford Powerstroke Diesel Forum
post #1 of 17 (permalink) Old 06-04-2009, 01:48 AM Thread Starter
star73's Avatar
DT466E Mods
Is there anything I can do performance wise to a 2000 dt466? Its only 195hp. I would like around 300 hp. Can I put 7.3 psd injectors in?
97 f250, ext cab, MBRP 4'' SS exhaust, 200/30's, D66 1.0 housing, Swamps IDM, ARP head studs, 910 valve springs, Smith bros push rods, Irate Efuel, Built E40D
2010 CCSB 6.4 IDP tuned
star73 is offline
post #2 of 17 (permalink) Old 06-04-2009, 02:01 AM
moore20017.3's Avatar
Re: DT466E Mods
I want to know the same thing.
Can a hybrid (AA body with BD p&B) be installed in a 466? With the 466 nozzles about 100% over of course.
This should empty way faster and be able to fuel better at higher rpm's. I want this dream to come to life......700hp 466 with twins in my red truck when the psd finally goes.
What all is necessary to the bottom end? Interesting
2008 F-250 SCLB Larait.
moore20017.3 is offline
post #3 of 17 (permalink) Old 06-04-2009, 02:07 AM
Re: DT466E Mods
Another thought.....is the CAT 3406 HEUI injector similar to the 466 and 444?
post #4 of 17 (permalink) Old 06-15-2009, 03:41 PM Thread Starter
star73's Avatar
Re: DT466E Mods
TTT
star73 is offline
post #5 of 17 (permalink) Old 06-16-2009, 07:15 AM
Custom Trailer Sales
TrailerHauler's Avatar
Re: DT466E Mods
I was wondering awhile ago! I believe it was smokeyreds boss or someone that put an 8.3 cummins in a superduty. Isn't the 466 a little smaller?
1999.5 F350 PSD CC Dually 05' Conversion
Stage I's - Gearhead Tuning - BTS - PCS
F550 rear suspension
1999.5 F350 PSD S/C 6spd Dually
R.I.P. Will Iott - "This ain't no practice run"
TrailerHauler is offline
post #6 of 17 (permalink) Old 06-16-2009, 07:36 AM
Senior Member
HPAddict's Avatar
Re: DT466E Mods
You'll have to either make a doghouse to fit the motor or relocate the radiator to make a dt466 work. That's a long mofo! Someone did it already, don't remember the name, but the pulleys were at the radiator.
HPAddict is offline
post #7 of 17 (permalink) Old 06-16-2009, 07:38 AM
Senior Member
HPAddict's Avatar
Re: DT466E Mods
I can't think of a reason the injectors won't work aside from the turn ing aspect of it. If you can use b codes in a psd, why won't it work the othe way around. How much oil will the stock hpop in it make?
HPAddict is offline
post #8 of 17 (permalink) Old 06-16-2009, 05:01 PM
fordtrucksrule7's Avatar
Re: DT466E Mods
did you try any of the programers out there, hell i think you can even go to the international dealer and the can turn it up more then that. proably not to 300 but whatever the highest output 466 is
fordtrucksrule7 is offline
post #9 of 17 (permalink) Old 06-16-2009, 05:26 PM
Body Type: MULE
CATdiezel's Avatar
Re: DT466E Mods
hmmm. Have never once in my life laid hands on a 3406 heui engine for some reason. I have a 3408/12. There injector bodies are COMPLETELY different...
A 3126b cat injector utilizes the body of a 7.3l heui
2011- F250 PSD CCSB 4x4 HS PERFORMANCE Tuning DPF OFF EGR OFF TRUCK HAPPY DRIVER HAPPY
your #1 NON-Cult member of the USA Government JustinM.
CATdiezel is offline
post #10 of 17 (permalink) Old 06-16-2009, 05:33 PM
6Leaker
jdc753's Avatar
Send a message via AIM to jdc753
Re: DT466E Mods
should be able to get it tuned up from International, at least for a start. I know our DT530 is rated at 275 and could be turned up by International to 300, trouble was it put the torque above the handling of the Alison trans so it never got turned up.
Looks like TS performance makes a chip for them. Start looking at tractor pulling I'm sure you could find a lot of go fast goodies there.
2005 F350 Crew Cab Long bed
6.0L / Auto 4x4
SCT X3 5" Magnaflow
4" RCD lift, a bunch of stereo gear and a computer
jdc753 is offline
Human Verification
HTML code is On
